Old 06-18-2010, 01:23 AM   #1
VRMMMM
VRMMMM's Avatar
Drives: 2010 Camaro 2SS/RS LS3
What clutch are you running if you got 470rwhp or more?
Are you able to daily driver it. Pros, cons? Where did you buy it? Cost for replacement should run about? Thanks for any advice.
VRMMMM is offline   Reply With Quote
Old 06-18-2010, 09:26 AM   #2
alfie43
alfie43's Avatar
Drives: S/C 2SS/RS Camaro-6M-VicRed
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Send a message via ICQ to alfie43
561 RWHP, not a DD, recreational driving only...the car has never seen rain.
No drag strip racing, but many all out 1st gear launches with speed shifting thru the gears, but no full throttle power shifting.
Stock clutch...no problems....so far.
Man, this is fun.
Alfie
alfie43 is offline   Reply With Quote
Old 06-18-2010, 09:33 AM   #3
Camaro21
Drives: SOLD - 2013 M6 ZL1
603RWHP with a Stock Clutch..
Camaro21 is offline   Reply With Quote
Old 06-18-2010, 09:35 AM   #4
LOUDMIKE
Drives: 2010 2ss, 1967 ss427, 1968 327
We have seen people using the stock clutch up to 600 hp. It to me is not just the issue of it handling the HP but the feel. I hate the stock clutch. It realeases late and grabs weird. My favorite clutch for the money is the LS7/Z06 clutch. Handles power great and a smooooooooth release point!! If you are wanting the more aggressive clutches we have had fantastic luck with Textralia's.
LOUDMIKE is offline   Reply With Quote
Old 06-18-2010, 10:52 AM   #5
DragonCamaro
DragonCamaro's Avatar
Drives: 2010 2SS/RS IBM
Textralia for the win...a lot of my friends have them or strongly suggest using them when you start modding you car and increasing your power output.
Ordered 2SS/RS IBM Manual -- NMCZV7
1100 : 16-DEC-08 Now 29 Jun 09
2000 : 24 Jul 09 3000 : 29 Jul 09
3300 : date unknown TPW 17 AUG 09
3400 : 17 AUG 09 3800 : 25 AUG 09 2G1FT1EW4A9139424
4000 :
4B00 :
4200 : 25 AUG 09 -- #ETTX820939
5000 : 4 SEP 09
DragonCamaro is offline   Reply With Quote
Old 06-18-2010, 11:29 AM   #6
alfie43
alfie43's Avatar
Mike
What can you tell me about the amount of pedal pressure on both the Textralia and the LS7/Z06 clutches. My wife is 5'-2" at 105 lbs...gonna need a clutch that she can handle.
Why is her opinion on the clutch so important? Its a long story.
Alfie
Old 06-18-2010, 11:35 AM   #7
LOUDMIKE
i will have to get you exact information on the pedal pressures as I dont have them in front of me. As far as the wife I totally understand. The ls7 clutch will handle what you are doing for everyday driving but if you decide to start tracking this car then I would upgrade to the Textralia z-grip. Little stiffer pedal but stronger. Just depends on what you decide to use the car for? I will get you the information onthe pressures and pm you today!! Thanks
Old 06-18-2010, 03:30 PM   #8
Roddd 1SS
Drives: 2010 Camaro 1SS
Alfie
That right there made my day! Thanks Alfie!!!
Roddd 1SS is offline   Reply With Quote
Old 06-18-2010, 04:56 PM   #9
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
LPE ZR1 Clutch, cant really tell the pressure difference with stock, but this one grabs like *&$%
BTW my car is my daily driver.
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 06-18-2010, 05:31 PM   #10
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
The LPE twin disk clutch and flywheel...Pedal difference...none
The release is much smoother than stock, pedal feel about the same but the thing sticks like crazy.
It's a toy not a daily driver, and yes it has seen plenty of track time, and the occassional cruise.
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 06-18-2010, 10:28 PM   #11
600hp-lpe
Drives: 2010
LPE ZR-1 clutch and flywheel.
It's a dream to use. Works perfect with a light pedal.
No problems whatsoever...
The stock one only lasted 1500 miles for me. went up in a cloud of clutch smoke... instead of tire smoke. the stock clutch sucks!
600hp-lpe is offline   Reply With Quote
Old 06-19-2010, 02:02 AM   #12
VRMMMM
VRMMMM's Avatar
damn, i just want something i can drive back and forth to work and on the weekends, get silly. I will push this car to 600rwhp max .. looking hard at the LS7 Clutch, just cause i have so many friend that swear by it. thoughts?
Old 06-19-2010, 10:42 AM   #13
GQ4Life
Drives: 2010 Camaro SS LS3
598wHP stock clutch.. go to track every weekend and drive hard on the street.. been 2,500miles so far with these mods.. (15K total)
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 06-19-2010, 11:24 AM   #14
TeddyP25
TeddyP25's Avatar
Drives: 2SS
578rwhp/595tq on stock, no problems at all.....Just ask the Challenger SRT8 from last night................
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
***STILLEN ACT Twin Disc Clutch System Intro Sale*** Team STILLEN Transmission / Driveline 55 01-08-2012 08:28 PM
NEW! Katech LS9X clutch for 2010+ Camaro Katech V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 03-11-2010 07:09 AM
Odd clutch and shifting issue for me. armysig Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 02-22-2010 11:36 AM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 09:52 AM
