03-25-2014, 04:11 PM | #1 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Camaro vs SS engines.
Doing a little research into a 2nd vehicle for use as a family/daily driver, I really like the looks/feel of the new Chevy SS sedan.
But one thing came up that I'm not sure about. The SS says it has the LS3 engine, but it also has the 6sp automatic transmission. Wouldn't this mean it has the L99 or has Chevy figured out how to marry up the LS3 to an auto trans?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
03-25-2014, 04:16 PM | #2 |
Drives: 2014 2SS rs 6M Join Date: Sep 2013
Based on what I have read it does not have cylinder deactivation. Hence the MPG numbers.
03-25-2014, 04:19 PM | #3 |
It's an ls3 hooked up to an auto. The l99 and ls3 designation has nothing to do with auto/manual. More the internals like afm and cylinder deactivation among other things.
03-25-2014, 04:21 PM | #4 |
Drives: 2016 Camaro 2SS, Red Hot Join Date: Feb 2014
It also has the gas guzzler tax, that is why the Camaro has the L99 with auto to avoid the tax.
03-25-2014, 04:53 PM | #5 |
Drives: 2SS/RS Join Date: Sep 2008
03-25-2014, 05:01 PM | #6 |
Or Pontiac G8 LS3
Life is short, drive it like you stole it! |
03-25-2014, 05:04 PM | #7 |
2010 2SS/RS M6
Ah, that makes sense. I've never really followed the L99 stuff since I've only ever had my LS3 Camaro.
03-25-2014, 05:40 PM | #8 | |
Drives: 2017 2SS Join Date: Mar 2012
As mentioned, the C6 Corvette used the LS3 with both auto and manual. But also mentioned was the gas guzzler tax. The Camaro is a much higher volume production car. The SS sedan will be pretty low volume in comparison. So, in order to meet the CAFE standards GM does some things that we as enthusiasts sometimes seem to think is stupid.
1996 Corvette - LT4
2017 Camaro 2SS 2019 GMC Sierra 2500 HD 2015 Harley Davidson Ultra Limited |
