#Camaro6
Go Back   CAMARO6 > Marketplace > Members Classifieds > Transmission / Driveline
Old 01-29-2019, 07:08 AM   #1
ocautomotive
Drives: 2017 ZL1 and 2018 SS 1LE
NEW ACT T1R-G09 CLUTCH 1140 TORQUE OEM PEDAL FEEL
I have a brand new ACT t1R-G09 clutch for sale, I bought it to install on the car but we are going with a th400 now so no need. Never installed, brand new. Discount is because it is out of box, however the spaced and hardware are still in packaging. Asking $900 buyer pays shipping.
T1R-G09 twin disc kit offers twice the number of disc surfaces for better wear, heat capacity and long life compared to single disc kits. These kits use a proprietary Positive Lift Floater System design, which results in quiet operation with no floater rattle and no posts to wear. ACT twin disc kits endure an exclusive four-stage, heat treating process performed on all diaphragms. The ACT twin disc features the ability to adjust for disc wear and provides equal disengagement for discs. ACT's 6-pad rigid race discs are made with high quality, ceramic friction materials. The chrome-moly hub is heat-treated for strength and durability. The lightweight, rigid design allows for quicker shifts and trouble-free service. All ACT twin disc kits include a CNC-machined and dynamically balanced flywheel to ensure trouble-free installation and operation. ACT twin disc kits include a pressure plate, two discs, a floater, flywheel and alignment tool. Some kits may include a pilot bearing and release bearing.
Feel - Light pedal effort, quicker shifts, aggressive engagement, mild to moderate gear rattle
Life - Doubles the number of disc surfaces for better wear, heat capacity and longer life, extended by ACT's exclusive diaphragm design
Quality - Carefully engineered, precisely assembled, accurately balanced, uses select ceramic friction materials for high heat tolerance and maximum performance
Recommended Use - Recommended for race use only
ACT Difference - 100% clamp load tested and dynamically computer balanced for smooth high RPM reliability
Torque Capacity (ft/lbs.):1140
Torque Capacity Over OE:73%
SFI:1.2
Flywheel Tooth Count:168
Disc Type:Race Disc
Spline Count:26
Spline Size (in.):1-1/8
Disc Diameter (in.):10.5
Disc Diameter (mm.):267
Product Weight (lbs.):43.2
Warranty (Product Warranty):One (1) Year from Retail Purchase
ocautomotive is offline   Reply With Quote
Old 02-03-2019, 02:46 PM   #2
SlydrSS305
SlydrSS305's Avatar
Drives: 2016 Camaro SS
Are you selling the TR6060?
Rotofab, PRAY IM/TB, SE 1 7/8 longtubes full system, SM FLEX FUEL KIT, Custom Exhaust, Mishimoto Catch can, FBO, street tuned.
SlydrSS305 is offline   Reply With Quote
Old 02-07-2019, 12:02 PM   #3
Terrellford12
Drives: 2010 SS/RS & 2017 SS/RS
Sold?.?.?..?.?.!
Terrellford12 is offline   Reply With Quote
Old 02-07-2019, 12:28 PM   #4
ocautomotive
Originally Posted by Terrellford12 View Post
Sold?.?.?..?.?.!
No
Old 09-12-2019, 04:00 PM   #5
Shocker91
Shocker91's Avatar
Drives: 2017 2SS, M6, Silver
Still available?
17 2SS, Pray Performance Forged/Stroked 416, 2.9 Whipple (Pray ported), Stage 2.5 Pray ported heads, RotoFab Big Gulp, Katech 103mm TB, Pray Performance stage 3 forced induction cam, 8.855” crank shaft lower pulley, 3.00 S/C pulley, LT4 Fueling, SMG auxiliary fuel system, 2' TSP LT headers with X-Pipe, Magnaflow Competition axleback, Mighty Mouse Wild catch can, Hurst Short Shifter. Tuned by Pray Performance. 1011WHP/982WTQ
Shocker91 is offline   Reply With Quote
