06-03-2019, 08:59 AM | #1 |
Drives: 2017 Camaro Join Date: Jun 2019
22's Didn't fit..
I recently purchased a 22" rim and tire set for my 2017 SS2 Camaro. Front tires rubbed at top inner area. *265/30-22 is the size I have that gave me issues* 22x 9.5 is the rim size. (Sizing found on inner rim area sais ET33 on all 4 rims. Does anyone know why I am having problems and or what I should do at this point?
06-03-2019, 09:54 AM | #2 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Well the ZL1's have 20 inch rims on them from the factory. And they just barley fit. So these larger rims, not working doesnt surprise me.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
06-03-2019, 10:12 AM | #3 |
Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
That tire is an inch taller than factory. You would need a lower profile tire I'd think. Keep the diameter closer to stock.
06-03-2019, 10:21 AM | #4 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
why not do what everyone does with ridiculously large wheels on cars not meant for them. Add lift to the suspension.
06-03-2019, 10:56 AM | #5 |
Drives: 2010 SS/RS & 2017 SS/RS Join Date: Jan 2009
This is mine. 22x9 in front with 245/25/22. And 22x10 on the rear with 315/25/22 you could also go 295/25/22 on rear or all around
06-03-2019, 11:13 AM | #6 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
you need to run all the old and new specs through willtheyfit.com
If the new specs are 4% taller or more than the old - you'll need to reevaluate what you want done. The offset of ET33 may be hurting you as well as I think the stocks are closer to 50. Anything more than 4% will also mess up your speedometer in that it will not show your correct speed. |
Tags |
22inch, rims |
