Old 06-19-2020, 09:22 AM   #1
KevinHoward8509
Drives: 2014 camaro ss 1LE
What kind of engine RPM's can i pull
Below is a list of the engine mod's i have on my car. i bought it used and am curious what everyone feels is a comfortable engine RPM for me to pull when at the strip. i am not sure what the rev limiter is set to as i did not have all the parts installed so not sure what the tuner set them at.
Engine
- Procharger P-1 Stage 2 Kit Intercooled
- HP Tuner
- ATI Super Damper 2% Underdrive Balancer
- AEM Wideband with Gauge
- TSP Supercharger Camshaft 224/240 .615/.615 112 +3
- Brian Tooley Dual Valve Springs
- Brian Tooley Chromoly Pushrods
- Brian Tooley Titanium Retainers
- GM 3 Bolt Conversion
- New GM Oil Pump
- Injector Dynamics ID 1050x Injectors
- Kooks 1 7/8" Long Tube Headers #6511
- Kooks 3" Catted (Hollowed Out) Exhaust 22505200
- JBA Power Cable Ignition Wires
- Mishimoto Aluminum Radiator
- Mighty Mouse Oil Catch Can
- Edelbrock (Red) Valve Covers
KevinHoward8509 is offline   Reply With Quote
Old 06-19-2020, 09:42 AM   #2
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Its not a matter of what you "can" pull its a matter of what RPMs are you making peak power at and should shift at to maintain the proportional gain at.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 06-19-2020, 09:48 AM   #3
KevinHoward8509
I agree 100%
I have the dyno chart but it was on a DYNOJET so i see wheel speed instead of engine RPM's.
Just trying to see what others are pulling the RPM's to on their cars i am going smaller pulley on my procharger and tuning it to E85 but i dont want to over spin the procharger. ive been shifting it around 6500k currently.
Old 06-19-2020, 09:50 AM   #4
NEstyle
Drives: Caprice
It also depends heavily on valvetrain stability.
All cars like different shift points. You will just have to experiment to see what it likes.
NEstyle is offline   Reply With Quote
Old 06-19-2020, 09:59 AM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
Peak HP is at 6600, peak torque at 5400. Everything after that is diminishing returns.
Vegas Bound is offline   Reply With Quote
Old 06-19-2020, 10:22 AM   #6
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
But, shifting right at peak power is not a strategy to maximize power. Rather, you need to look at the power curve before and after the peak HP in conjunction with shift recovery rpm drop to determine shift points. A car with a big converter may only need to go a couple hundred RPM beyond peak as it may only have 1000rpm of shift drop. A stick car can have more than double that, my 1-2 and 2-3 shifts have over 2200rpm of shift recovery rpm drop. In either case, you want to have the highest average hp throughout the duration of the gear.
In my stick car, I make peak power at 6500rpm, but I target a 7200rpm shift point. That puts my shift recovery rpm drop at right about 5000rpm. This gives me the best average HP with my combination. If I was to shift at 6500 (peak hp) then my shift recovery rpm drop would be at 4500rpm - and that range would yield less power, and less acceleration.
So, back to the original posters question - with a centrifugal peak power usually just keeps climbing as you increase the rpm (and therefore the boost), and they typically will like a nice high shift point. That said, you don't have a particularly aggressive camshaft or pulley combination, and there will probably be a point where it starts to roll over. It's a guess, but I would think that will like a shift point somewhere in the 6700-7000rpm range, depending on where shift recovery lands.
Is it stick or auto? What converter, what gears? Lets see the dyno graph, we can probably infer a few things from what we see there.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 06-19-2020, 10:37 AM   #7
KevinHoward8509
attached is a copy of the dyno sheet.
The more comfortable i get with the car the more im willing to push it. i was shifting around 6700 rpm the last couple days and am noticing how much nastier it is up there which understandably so being the way its setup.
The car is a M6 with a 3.91 rear end. the current pulley setup is a 3.90 on the top and a 7.625 on the bottom and i want to go with a 3.40 on the top but if i pull 7000 RPM's that will put me at 64,500 impeller rpm's and max on the p1sc is 65k so i dont want to pull that many rpm's.
i mostly street race and just get on it from time to time i dont go to the track and just run the shit out of it for a half a dozen pulls but i do run my car harder than i would say most do while daily driving.
Old 06-19-2020, 10:52 AM   #8
Vegas Bound
I spin my LSA to 27000 rpms on a max of 24000. Send it.
Old 06-19-2020, 10:58 AM   #9
KevinHoward8509
haha!!! my buddy keeps telling me the same thing.
Between that and the 12-13lbs of boost ill be running on E85 i feel like im pushing everything to the max haha.
Old 06-19-2020, 11:35 AM   #10
acammer
acammer's Avatar
Looks like it peaked at 138mph, which is ~6500rpm on a 28" tire. With a stick I'd definitely target a 7000+rpm shift. I'm sure it would carry out pretty good as far as you're willing to spin it with a centri - it really becomes a question for the valvetrain.
The 660 platinum should be ok out to that 7500 range, Ti retainer is helping keep it light. Stock LS3/7 lifter I start to question out past 7000 and start to recommend GMPP's or 2110's when we put together cam packages. That said, my stock 42k mile LS3/7 lifters and 660's with tool-steel retainers see 7200 regularly, and have been out to 7600+ on a few occasions without issue.
I would maybe start by targeting a 7000rpm shift. If you're at the track and pretty consistent in your trap speed you can try a pass shifting at 6700, and another at 7300 to see if you make any noticeable gains/losses.
Old 06-19-2020, 12:02 PM   #11
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I'd also say set your limiter to 7k-7200 and see how it feels. you need a little rpm buffer in the lower gears as the rpms climb quick. I need to bump mine a couple hundred rpm I think its at 6800 I peak at 6700 I don't have enough time to shift in the lower gears before I hit the limiter as the car still feels like it's pulling.
Greenhornet2 is offline   Reply With Quote
Old 06-19-2020, 02:48 PM   #12
Vegas Bound
Try 17.5 lbs on e85.
Old 06-19-2020, 03:03 PM   #13
KevinHoward8509
is that a joke haha.
The pulley i ordered should get me abour 12-13 and thats all the p1sc can put out for me. Ill be spinning close to max RPM's for that blower.
Old 06-19-2020, 04:37 PM   #14
Vegas Bound
No joke. At sea level, I make 17.5 lbs and use e85. At altitude, I'm down to 14.
