03-10-2012, 07:07 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Jul 2011
Exhaust tips that work with the oem ground effects
I have a Borla Atak Cat-back installed with the tips which don't work with the ground effects. So, before I install the ground effects I will have to replace them with ones that do. Any suggestions on what I should get?
03-10-2012, 07:42 PM | #3 |
The Borla ATAK that is for the cars with GFX is simple the Borla ATAK without tips.
03-10-2012, 07:57 PM | #4 |
Drives: '10 2SS/RS, MKIII Supras Join Date: May 2010
MBRP tips are what I have on my Camaro with gfx. I ordered them from Ivan @ Southwest Speed.
03-10-2012, 09:18 PM | #5 |
Drives: 2000 Camaro SS, 2012 2SS/RS Join Date: Aug 2011
I've seen threads where people say they just cut off some pipe behind the exhaust tip to shorten it then they just have it welded back on so that it fits inside the exhaust bezels, similar to how the stock ones fit. I think this would work better than the other kit that borla sells with just no tips.
03-11-2012, 01:30 AM | #6 | ||
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Link to price for C5ers: http://www.southwestspeed.net/index....ts/product/138 Best selling and performing tips I've heard and seen for the GFX Cars! Ivan @ Southwest Speed |
03-11-2012, 02:13 PM | #7 |
Thanks for the info guys! I know borla sells the kit without the tips, but at the time I hadn't planned on getting the ground effects, so I went and ordered the kit with the tips. This was back in September. I just bought the ground effects yesterday
03-11-2012, 02:17 PM | #8 | |
03-11-2012, 06:43 PM | #9 |
Drives: 11 2SS/RS M6 vert Join Date: Dec 2010
I have the Borla S type and the MBRP tips. I can't find any adapter pipes to go from the Borla 2.5" to the MBRP 3". Has anyone found anything?
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
03-13-2012, 01:27 AM | #10 |
Drives: 2018 ZL1 Conv. Join Date: Jan 2012
I had to have a muffler shop make then out of 2.5" stock. Cut at 6" and then expanded. Then I welded the whole assembly to my exhaust pipes. But I am sure you could use band clamps to connect it.
Similar Threads | ||||
V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 05:56 PM |
Looking for OEM ground effects, front splitter only | nomadicdogg | Exterior Parts & Accessories | 1 | 02-06-2012 03:13 PM |
Exhaust Tips For SS With Ground Effects??? | PC HOTROD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 06-28-2011 01:45 PM |
Exhaust Tips For SS With Ground Effects??? | PC HOTROD | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 5 | 03-30-2011 04:31 PM |
Square exhaust tips to match ground effects | brooks35 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 09-07-2009 08:20 AM |
