01-17-2013, 01:27 PM | #1 |
Drives: 2011 Camaro 2ss M6 Join Date: Mar 2012
Anybody run stock tires on your 500wrhp car?
Anybody run the stock 275 on this much power? Do you get any traction at all?
01-17-2013, 01:50 PM | #2 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Ya, itll have no problem spinning them. If you roll into the throttle instead of mashing it, they have a better chance of holding. But ya, if you just mash it, you'll have no chance of traction.
2010 Camaro SS LS3 - No Modz
01-17-2013, 02:05 PM | #3 |
Drives: '10 CGM SS/RS Join Date: Nov 2009
yeah, forget flooring it...spin city. Rolling on it smoothly controls the spin depending on the outside temp. I find when it's less then 60 degrees out, they spin regardless when the tech gets up there but 70+ degrees you can control it if your smart about it. Fun problem to have actually
'10 1SS LS3...all the usual suspects
504/470 NA |
01-17-2013, 02:19 PM | #4 |
Banned
Drives: 10' 2SS LS3 M6 Join Date: May 2012
I had no traction on 315 vredesteins..
01-17-2013, 02:49 PM | #5 |
Ok. Well ill be going to 305 later on but I might as well use these tires up. No point of wasting
01-17-2013, 02:50 PM | #6 |
Camper are those tires more all weather or performance?
01-17-2013, 02:56 PM | #7 |
Banned
performance summer tire
01-17-2013, 04:35 PM | #8 |
Stroked and blown
yes, not an ideal situation but yes. You control the acceterator and clutch.
01-17-2013, 04:50 PM | #9 |
chevy pride
im been racing on my stockers at 460rwhp and 125shot , just got to roll into it. i ran a 11.7 on them with the 460 and a 50 shot.
check out ky speeds fb page https://www.facebook.com/kyspeed |
01-17-2013, 05:29 PM | #10 |
Drives: Fire Engine Join Date: Oct 2008
I'm still using the stock tires running low 11's at the strip. On the steet, gotta be gentle with the throttle tho.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile 11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires. Sold |
01-17-2013, 06:26 PM | #11 |
Drives: '02 Trailblazer, '12 Camaro 2SS/RS Join Date: Jun 2012
01-18-2013, 12:40 PM | #12 |
Drives: 2010 M6 2SS Join Date: Mar 2011
I don't know that I agree that Vredesteins are a performance tire...I like mine a lot, but I think they're more of a good wet weather tire that is very quiet and nice to live with. They're not that sticky, and the sidewalls are pretty pathetic in corners.
At 500RWHP, first gear is funny unless I'm on drag radials...second gear is hit or miss...depends how hard I shift, how warm it is, and how nice the pavement is.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
01-18-2013, 03:41 PM | #13 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Just be extremely careful in colder weather.
The stock tires can't even handle stock HP levels in cooler air (colder road temps). When I had the stock P-Zeros on my car they had almost no grip in temps below 50 degrees or so. But in summer temps (90 degrees), the P-Zeros are sticky and work well. |
01-18-2013, 04:21 PM | #14 | |
