#Camaro6
AWE Tuning
Old 09-12-2016, 05:25 PM   #1
Camaroky
Camaroky's Avatar
Drives: 2016 camaro 1SS
Manual transmission (put in reverse when parked)?
I've seen a few posts here about batteries being dead, and was wondering if it's in a majority of the M6.
When I got my M6 SS the dealer told me to put it in reverse when ever I parked it. Reason being is that when the shifter is in reverse, that it shuts down more of the electronics in the car.
Has anyone else been told this? Or is the dealer just
Camaroky is offline   Reply With Quote
Old 09-12-2016, 05:53 PM   #2
MovieGuy
MovieGuy's Avatar
Drives: 2016 Camaro 1LT
I have never heard this. I was taught to put it in reverse because reverse is the lowest gear, and therefore the most difficult one to move the car in, when I was in drivers ed.
http://www.camaro6.com/forums/image.php?u=115947&type=sigpic&dateline=1461721697
Life after retirement
MovieGuy is offline   Reply With Quote
Old 09-12-2016, 05:58 PM   #3
Camaroky
Camaroky's Avatar
I've always left it in 1st on level ground or when facing uphill. If I face downhill then I would put it in reverse. Don't really know if either way makes a difference.
Just never heard of putting it in reverse to shut down more of the electronics when the car is parked.
Old 09-12-2016, 06:04 PM   #4
Wiskey
Drives: 2016 Chevy Camaro
I've not heard of the reverse thing shutting down electronics either. For me it's simple, if I pull into a spot I leave it in first, if I back into a spot I leave it in reverse.
Whiskey
Wiskey is offline   Reply With Quote
Old 09-12-2016, 06:06 PM   #5
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
If you're parked between cars, it's preferable to just leave it in neutral: this way, if somebody bumps you, it doesn't harm the transmission. Just make sure you've got the handbrake firmly set.
If on a hill, 1st gear if facing uphill; reverse if facing downhill. Just make sure to set the parking brake before releasing the clutch, so that the weight of the car is on the brake first; the gear is there only as a backup should the brake fail.
MiamiBlueCamaro is offline   Reply With Quote
Old 09-12-2016, 07:08 PM   #6
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
That applies to the first production year of the 6th generation Corvette.
Laborsmith
laborsmith is offline   Reply With Quote
Old 09-12-2016, 07:16 PM   #7
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
whoa... i would never leave it in neutral and rely on the e-brake alone. I'm not sure what your concern would be if the wheels turn the transmission (and engine)... this is normal load on the tranny.. unless someone smashes into your car, then you have bigger issues anyway
crazydmc is offline   Reply With Quote
Old 09-12-2016, 07:28 PM   #8
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I usually have it 2nd....maybe 3rd...could be 4th for all I know. Never have put a manual car in reverse.
Had 4 of them over 10 years of driving, a couple 100,000 miles, just left it in gear, it didn't matter and never an issue.
BradfordCamaro is offline   Reply With Quote
Old 09-12-2016, 10:59 PM   #9
SkipNWis
SkipNWis's Avatar
Drives: 2016/SS Has had 4 Gen 5's
I read they other day riding with you hand on the shifter isn't a good thing? I seems to always have my hand resting on the shifter ?? What's your Take on this ????
SnoWhite
SkipNWis is offline   Reply With Quote
Old 09-12-2016, 11:17 PM   #10
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
Nothing in the manual transmission is electronic besides the switch for the reverse lights in reverse.
All of the electronics are managed by the ECM. I am quite sure based on your dealer's advice they have no idea what an ECM is and you should never take your car there for service. They probably have never seen a tire before either.
I cannot believe how stupid people who work at these dealerships are. I mean seriously. People wonder why salesmen get such a bad rap...... Stuff like this! I mean, just..... wow.
fastball is offline   Reply With Quote
Old 09-12-2016, 11:28 PM   #11
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
It wears out the bushing. You'll just have a sloppy shifter. My dad does that in his semi and his shifter has all kinds of play, but works perfectly fine. I don't tend to in mine and my shifter is tight
Dubchitts is offline   Reply With Quote
Old 09-12-2016, 11:40 PM   #12
BradfordCamaro
SABIO
I can repeat my statement above many miles, many years and never an issue with my hand on the shifter. Just resting on it playing with the radio. Not putting force on it.
Too many wives tales about manual transmissions.
Old 09-13-2016, 09:19 AM   #13
Bobfly
OspreyTech
Bobfly's Avatar
Drives: 2016 Camaro 2SS
I always leave it in 1st unless I'm in my driveway and then sometimes I put it in reverse. Doesn't really matter one way or the other. My hand is always resting on the shifter too. You just never know when one of those pesky mustangs is going to pull along side.
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
Bobfly is offline   Reply With Quote
Old 09-13-2016, 12:04 PM   #14
Android42019
The Black Emerald
Android42019's Avatar
Drives: '17 ZL1, '08 Trailblazer, '11 1LTRS
Shuts down electronics? The smoke he must blow to other customers..... I've NEVER heard this before, reverse is just the hardest gear to manually move the car in.
Android42019 is offline   Reply With Quote
