Old 12-07-2010, 07:28 PM   #1
g-townmach
I FARTED
Drives: 2010 2SS/RS
So did the TPMS issue ever get solved?
I haven't been very active on the forum lately so I didn't get to read what became of the tpms issues people were having. All I remember was GM changed the frequencies.
g-townmach is offline   Reply With Quote
Old 12-08-2010, 08:35 AM   #2
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I'm curious about this too! I was told by GM Parts Direct that the TPMS sensor part number for my 2010 Camaro SS was 12768826, but that part number has now been superceded by 20922900. But since reading about the different frequencies, I'm not sure which of these or both will work for my early vin. To complicate matters even worse, Forgeline is telling me I need to get GM sensors that have an aluminum valve stem so that they will mount to their TPMS sensor brackets. So, now I'm really confused as to what I need!!! Any help would be greatly appreciated!!
blazzin1 is offline   Reply With Quote
Old 12-08-2010, 05:23 PM   #3
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
I've not heard of any news regarding the Camaro TPMS issues. The only safe bet at the moment is to use actual GM part# sensors. Your parts dealer can use your VIN# to search for the recommended sensors for your car. These will not have an aluminum valve stem, they are all rubber stem sensors.
Tony
Fquick.com/NineBall
Old 12-08-2010, 06:27 PM   #4
55Designs
Drives: 2010
I think on custom rims and i found this on almost all, the OEM sensors do not sit right on the barrel of the rim. What we are going to test next week is some thick dense VHB tape under the sensor to stop it from moving when its in motion. I think this is whats setting our fault off when we hit bumps in the rear wheels only. sensors are too prone to shock which can throw off the sensitivity They need to be secure and I am confident the aftermarket 315mhz units will work if mounted properly. Its very annoying to say the least.
55Designs is offline   Reply With Quote
Old 12-08-2010, 06:28 PM   #5
55Designs
Drives: 2010
We have the Forgeline parts in stock you need to have a hole drilled in your wheel barrel to use there brackets. Did Forgeline do this for you already? Do you have the 90 degree stem? Gotta speak to David.
Old 12-08-2010, 06:31 PM   #6
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
when i bought my replica's from discount tire I had them install new sensors on the wheels. had to reset them once, but golden since.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 12-08-2010, 09:09 PM   #7
blazzin1
blazzin1's Avatar
Yep, my new (used) Forgelines supposedly have the correct hardware for mounting the sensors inside, and they do have the 90 degree stems. But since they came off a BMW, I need to remove the BMW sensors and install GM sensors. However, David told me to make sure I order the GM sensors with the aluminum valve stems, so now I'm confused about what part number to order. Or if the sensors from my factory wheels will work?
Considering coilovers, but I need a solution for the TPMS stem rubbing. Berean Wheels and Tires Talk Sponsored by The Tire Rack 27 09-05-2010 12:47 PM
Dealership stole my TPMS sensors! MacTruck 5th Gen Camaro SS LS LT General Discussions 47 04-20-2010 10:18 PM
HVAC issue... Anyone had this problem? nashstat 5th Gen Camaro SS LS LT General Discussions 8 01-27-2010 04:19 PM
Interesting TPMS Dash Warning Light Issue Hicompression Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 01-12-2010 08:35 AM
Another Paint Issue 2032Ceta Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 08-16-2009 08:59 PM
