Old 03-13-2012, 10:44 AM   #1
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Power Steering Pump Pulley
Well when I changed my timing chain cover gaskets, and my water pump gaskets (because the water pump was leaking), I had to take the PSP pulley off and what not.
During taking it off, it warped and now at an idle it wiggles a little bit. Its been fine but now its starting to squeal real bad and loud when I hit the gas. I sprayed it with WD-40 while holding the throttle a little and it went away for a split second so I know that this is the problem.
Autozone doesn't sell it, and advanced auto parts does not sell it. I was going to try car quest but I doubt they will have it either. I found one online for $25 free shipping but its for the 3.8l v6. Are they the same on the 3.8 and 3.4? Thanks.
Animated Gif not allowed
Ant32894 is offline   Reply With Quote
Old 03-13-2012, 04:29 PM   #2
OffseT
Maroboy2001 AKA Offset
OffseT's Avatar
Drives: Boosted Trans Am
Not an expert but cant autozone order it?
OffseT is offline   Reply With Quote
Old 03-13-2012, 06:22 PM   #3
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Nah. I went to the junkyard and got one in mint condition. Does it need to be pressed on with a tool?
Old 03-13-2012, 08:12 PM   #4
fbodyrs96
fbodyrs96's Avatar
Drives: 1996 Camaro RS convertible
Yes Autozone rents the tool
fbodyrs96 is offline   Reply With Quote
Old 03-15-2012, 06:36 AM   #5
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
So my friend decides to tell me that he stripped the shaft taking the pulley off when he fixed my car, and he had to bang the pulley on (He didnt know it was a press on I think) and so now my shafts bent and stripped. I need a whole new power steering pump...... People suck.
Old 03-15-2012, 06:54 AM   #6
Matster
Matster's Avatar
Drives: 2010 2SS/RS IOM/IOM #3625
Probably just as well cause if you ran the car any amount with the bent pulley, the bearings would have been the next thing to go anyway.
666 EVIL RWHP BUILT AND TUNED BY SHIFTED PERCEPTIONS INC.(SPi)
416 Forged Stroker, E-Force Supercharger, Blower Cam, Rotofab CAI, Stainless Works 2" LT Headers and 3" Exhaust, LPE ZR1 Twin Disc Clutch, DSS 1400 HP Axles, Pfadt Performance Kit Stage 3.
Matster is offline   Reply With Quote
Old 03-15-2012, 11:40 AM   #7
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
+1 I'd be telling your friend he needs to pony up some $$$ since he busted it.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 03-16-2012, 11:19 AM   #8
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
the pumps should be the same between 3.8 and 3.4, but I can't be sure off hand.
but now, you'll need a new pulley as well.
I don't remember if the v6 pump is the same as the v8 pump on 4th gens. if it is, in the future, instead of pulling the pulley off, you could just unbolt the whole pump assy to save yourself some hassle
(this is a diagram of the LT1 style pump, again, not sure if its the same)
http://shbox.com/1/steering_system.jpg
I piss excellence
and fart awesomeness
Old 05-15-2019, 01:02 AM   #9
elmarco
Drives: Chevrolet Camaro V6
I know this is a weird question, but I am replacing my power steering lines and I heard that the pulley shouldn't have any play what so ever. if there is once it is fully on, is that a sign I should just replace the whole pump altogether?
elmarco is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 04:44 PM
E85 TUNE RESULT!! bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 327 10-13-2011 06:22 PM
CEL - P1682 PSU SS Tuning / Diagnostics -- engine and transmission 4 09-29-2011 07:27 PM
Billet Power Steering Pulley GJG Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 09-25-2010 07:26 PM
Removing power steering pulley 350 HRSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 06-13-2010 08:58 AM
