Old 08-03-2012, 02:54 AM   #1
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
NEED HELP BADLY
I need help badly because I got pulled over 3 times tonight and I don't know what this problem is.
Yesterday my driver side blinkers were working fine, then suddenly it wouldn't click back after I made a turn.
Now this morning the rear taillight went out so I changed the bulb, but now the blinker still wont work. I can make them flash manually but it will not do it by itself, it just holds the lights on (which usually means a bulb is out but they are not)
When the lights are on, the taillight is always bright (which it is supposed to brighten up when you brake). So when its dark out, I keep getting pulled over for no blinker/brake light. But they were understanding and let me go luckily.
Can anyone diagnose these issues? Im thinking blinker box? And does anyone have a diagram on how to get into the steering column?
I suck at most electrical things lol. I'm all motors :/ .. Appreciate it guys.
Animated Gif not allowed
Ant32894 is offline   Reply With Quote
Old 08-03-2012, 07:36 AM   #2
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
You might need to replace a fuse.
3" Magnaflow cat-back, MSD 8.5mm Super Conductor Wires, NGK Iridium plugs, KN Air Filter, Halo Headlights, Shaved Air Lid, Chrome ZR1 Rims, SS Hood Scoop/Spoiler
Lee0123567 is offline   Reply With Quote
Old 08-03-2012, 08:39 AM   #3
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Never had this issue on a 4th gen, but it may need a new relay, fuse (as mentioned above), or flasher solenoid thingy (sorry, I can't think of the correct name!).
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 08-03-2012, 10:36 AM   #4
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
I looked at a wiring schematic for your car, and the system is very basic. Double-check the bulb you installed. It is either incorrect, defective, or installed incorrectly. That's really the only way the "bright" side of the bulb would be lit up when the lights are on. It would also cause your no-flash for that side for the turn signals.
Also check the socket carefully. Make sure nothing is melted, cross contacts, or broken. Post up when you find the problem.
Bye bye, Bumblebee!
Old 08-03-2012, 03:09 PM   #5
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
The bulb is correct, nothing is cross contacting it, nothing is broken, or melted. I am going to have to go with the relays?
Old 08-03-2012, 10:45 PM   #6
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
The bulb was put in backwards? HOW THE HELL CAN A BULB GO IN BACKWARDS!? I feel stupid now lmao. But now when I make turns it does not automatically click back, so im guessing its a blinker box or whatever its called.
Old 08-04-2012, 03:10 AM   #7
cowboy74
Drives: none at this time
easy fix for your issue i had the same thing with a 84 s10 i had years ago change the flasher out mine were sticking and at times thewould stick and i would have to flip the stalk manually i replaced the flasher 6 times while i had the truck hope this helps you some the flasher is normally under the left side of the dashon gm vehicles i have changedsome for family and friends over the years good luck and hope ya get it fixed
cowboy74 is offline   Reply With Quote
