Old 06-09-2020, 09:34 PM   #1
leemozoid
leemozoid's Avatar
Drives: '15 Silverado LTZ & '13 ZL1 ragtop
2 Step
Are there any manufacturers making 2 steps for Gen 5 ZL1 autos? I know that there are plenty for the SS and the stick comes with it's own rev limiter. All tips appreciated.
HP tune, Kooks 1 7/8" LT w/ cat deletes, FIC 1300 inj, E85, GPI SS3 blower cam, Fore Innovations Gen 5 dual pump module with twin TI Automotive 430 lph E85 compatible pumps, Lingenfelter 10 bolt 2.55" upper/9.17" lower pulleys, AFCO triple pass intercooler with dual fans, Killer Chiller interchiller, B3R insulated expansion tank, full BMR rear drag cradle and suspension, DSS one piece driveshaft and Stage 5 billet axle shafts, Rotofab CAI, reinforced brick, Devil's Own progressive methanol injection, FTI 9.5" billet lock up Street Racer torque converter, 3200 rpm stall, triple clutch.
leemozoid is offline   Reply With Quote
Old 06-10-2020, 10:13 AM   #2
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
What is a 2 step?
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 06-10-2020, 10:27 AM   #3
ZL1 Maniac
ZL1 Maniac's Avatar
Drives: 2014 ZL1 Red Hot M6
Originally Posted by 2013ZL1FUN View Post
What is a 2 step?
It’s basically a 2 stage rev limiter.....
You can set it to say 3800 rpm for launch and then an upper limit like 6500.....
ZL1 Maniac is offline   Reply With Quote
Old 06-10-2020, 10:42 AM   #4
608RS
608RS's Avatar
Drives: 2015 2ss
https://www.lingenfelter.com/product/L460216509.html
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 06-11-2020, 08:58 PM   #5
leemozoid
leemozoid's Avatar
Originally Posted by 608RS View Post
We'll give it a try. Thank you.
Old 06-15-2020, 08:48 AM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
LNC-003 LAUNCH CONTROLLER/2STEP
That's a Lingenfelter set up as well.
We can also get the MSD two step. Very easy to use and install.
Juiced1 is offline   Reply With Quote
Old 06-15-2020, 10:17 AM   #7
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
The N2MB WOT Box is a little more universal and requires a little more wiring, but is a nice unit with a very nice GUI for setting up all the functionality. Very happy with mine.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 06-15-2020, 11:25 AM   #8
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
The LNC-003 can be used on the 2009-2013 ZR1 Corvette (LS9 engine), the 2009-2014 Cadillac CTS-V (LSA engine) or the 2012-2014 ZL1 Camaro (LSA engine) but you will need to change the connectors because the LS9 and the LSA use a different combined coil and fuel injector harness. Contact LPE for these connectors (part #s 15336037, 15422562, 15326939, 15336034)
ZMEnow is offline   Reply With Quote
