06-29-2020, 06:38 AM | #1 |
Happy_Dan
Coilovers on ZL1
I have been searching the forum to find out if anyone has replaced the Mag Ride with coilovers. Does someone make a plug in device to fool the computer?
I am thinking about switching the mag ride out but I know that the computer is looking for signals from the mag ride. Last edited by Happy_Dan; 06-29-2020 at 08:27 AM. |
06-29-2020, 07:03 AM | #2 |
What would be the advantages of coil overs?
06-29-2020, 08:27 AM | #3 |
Happy_Dan
Less expense over time. The front are now 400 to 500 each. They are going up and I am not sure how easy they will be to get later. Coilovers will last longer and easier to replace over time. I love the mag ride, but I have a leaky one at only 35K miles.
06-29-2020, 09:14 AM | #4 |
Drives: 2013 ZL1 Camaro Join Date: Feb 2018
Didn't ZMENOW say they now have a lifetime warranty when purchased from the right source? Mag ride is a big part of what makes it a ZL1!
06-29-2020, 10:10 AM | #5 | |
Happy_Dan
It is an easier choice if there is no plug and play module to fool the computer. I believe that the 2012 ZL1 Coupe with F55 for fronts is part numbers: AC Delco - 580-428 and 429. Can someone verify that as well. |
06-29-2020, 02:32 PM | #6 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
You have an FE5 suspension from what I have read on your thread. The MAG deletes have gotten cheaper over the past for years but still not cheap. https://www.phastekperformance.com/a...6-401002-n.htm |
06-29-2020, 02:47 PM | #7 |
Happy_Dan
Build sheet says F-55. Not sure if that is the suspension or a variant of FE5.
Do you have part numbers for FE5?
06-29-2020, 02:50 PM | #8 |
Happy_Dan
Wow, $350 plus the cost of the coilovers. Looks like I will have to order some mag ride struts/shocks.
Now I need to make sure on the part numbers because I won't do them now unless it gets much worse. It is only a minimal leak at this point. |
06-29-2020, 03:31 PM | #9 |
Not sure what you are seeing but a coupe would be FE5. Those ACDelco numbers look good. You can go to AC Delco’s website and plug you Year, make, model.
06-30-2020, 09:28 AM | #10 |
Drives: 2013 ZL1 Join Date: Dec 2019
I installed Ohlins coilovers on my ZL1. The biggest issue is the car will throw a code and limit the top speed to 85mph. This can be tuned out by raising the limiter with the gm tuning tool. I forget the name of the tool but it is mentioned under my old user name if you search for Ohlins coilovers on this forum.
06-30-2020, 03:45 PM | #11 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
IF or when the time comes for me to need to buy them if the price is still this high on mag shocks I might go with a softer SS strut as I don't road race mine and these parts, based on this thread:
(a $10 DIY kit) https://www.ctsvowners.com/threads/m...lution.109305/ https://www.alliedelec.com/product/o...3r-f/70596832/ https://www.amazon.com/ADWITS-Therma...07X81PRK7?th=1 (to put between the resistor and the metal part it's mouned to) |
06-30-2020, 10:33 PM | #12 |
I bought a resistor kit, but they blew out eventually. I don't know the Watt rating of the kit. Adjusting the speed limiter eliminates the impact of the code. I clear the DIC warning with the menu button.
