04-12-2015, 10:34 PM | #1 |
100 Octane
Hey all my Louisiana guys and gals, where around here can I get 100 octane from the pump? I can't seem to find anything searching online so I figured I'd ask on here. I'd maybe look into filling my car with it all the time and tuning my car to 100 rather than 93. What kind of horsepower difference would it make tuning it for 100? And how much more expensive is this type of octane?
04-13-2015, 12:06 AM | #2 |
if you cant find it everywere I wouldnt be tuning for it. 1 station used to sell it next to the race track in lancaster NY. it was $2.50 more than 93. That was when 93 was $1.50.
04-13-2015, 07:34 AM | #3 |
Here in Florida its $8.99/gal! I only use it when I race.
04-13-2015, 08:12 AM | #4 |
Try the private aircraft terminal at the airport.
04-13-2015, 08:34 AM | #5 |
Drives: 2015 2LT/RS Vert Join Date: Mar 2015
Not a good idea if you have cats. The lead content in 100LL will contaminate them.
Mel
2015 2LT/RS 'Vert, RRM/Blk Designated Airworthiness Inspector; specializing in Amateur-Built and Light-Sport Aircraft. USAF Vet. <n168tx(at)flytx.net> |
04-13-2015, 10:49 AM | #6 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
I run 93 Octane at the track, no point in running 100 or something crazy expensive. Especially when I burn through a 1/4 tank or so every 25 minutes.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
04-16-2015, 07:28 PM | #7 | |
Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
04-16-2015, 07:30 PM | #8 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Lucky people in Kansas we can only get 91 octane max
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
04-16-2015, 07:59 PM | #9 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
California is just 91 max.
04-17-2015, 06:50 AM | #10 | |
Also, running a higher octane than required can actually make less HP because your basically wasting energy. The whole point of higher octane is to run more advanced timing or higher compression, and you can only do so much with the timing, otherwise you're throwing money away.
2010 2SS
04-17-2015, 10:32 AM | #11 | |
The manufacturers try to make modern cars idiot proof, but sometimes, I don't think they don't realize the caliber of idiots that they are dealing with.
04-17-2015, 07:03 PM | #12 |
Try looking into this: http://race-gas.com/
TSP 1 7/8" Headers, Cat Delete / Flowtech Mufflers, Vmax CNC Ported TB, SLP UD Pulley 25%, Elite Catch Can, Vararam CAI, Vararam Power Wedge, Taylor 49 Race Wires, Mishimoto Silicone Hoses, B&M Transmission Pan,
Tampa Tuning Tweaked & Tweaked again |
04-17-2015, 08:32 PM | #13 | ||
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
I used to work at Santa Rosa airport fueling aircraft at 'Sonoma Aviation' soon after I got out of the service. I used to drive this 1978 Toyota Celica 5speed that I pretty much beat to shit. It was a fun little ride. Used to drive from Santa Rosa, CA to Lemoore, Ca (about 300 miles) to see my then Girl Friend.... little bugger was fast too. One of the benefits of working at a small airport was being able to use 100 Low Lead on that ride (among other things, of course). It definitely gave it some power, but you could also smell the cats burning hot... too hot I think. I eventually left Santa Rosa CA for SoCal, and I owned that little ride for a good while after that. The tranny blew before the cats went once it was finally done.... tho, not sure if there were any cats left. Got it for $250, sold it for $100 tore up and that was that. Moral of the story - don't use 100LL if you've got cats on. Will add power tho. |
04-17-2015, 09:43 PM | #14 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
