Old 08-11-2012, 09:56 AM   #1
Dentyneice
Drives: 2010 Camaro 2ss
How to replace rear blinker light?
I started to get a message on my dash saying Check rear blinker light. What's happened is whenever I use my right turn signal, the message comes up and the blinker flashes twice as fast as it should. I walked out to check the light and the Right, rear, Inside blinker light isn't flashing and that the outer right blinker flashes twice as fast.
Can someone make a DIY guide for this? My bumper to bumper expired 1500 miles ago :(
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 08-11-2012, 10:02 AM   #2
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
Very easy inside your trunk on the right you will see a black plastic cover with 3 push pins I used a flat head screw driver to pry them up after you get them up pull the plastic up and reach in and twist the bulb housing and pull it out then just swap the bulbs
MikeMoach is offline   Reply With Quote
Old 08-11-2012, 10:04 AM   #3
Dentyneice
Sounds easy. Would you happen to remember the info for the bulb you bought?
Old 08-11-2012, 10:07 AM   #4
Chris-10
Chris-10's Avatar
Drives: 2ss/rs vr 6m
Old 08-11-2012, 10:08 AM   #5
MikeMoach
MikeMoach's Avatar
When I get out of work I'll get the info but If u go to autozone or somewhere they can look it up and tell you
Old 08-11-2012, 10:40 AM   #6
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
10 minute fix. Bulbs are standard 3157 long life. most common is Sylvania 3157 LL They come in a pack of two so replace both. Any auto store will have them.
Open trunk. Right side right above the lights remove the black triangle plastic. It has 3 push pins in it. Use a trim removal tool or screwdriver to pull up gently on the inner pin. Once it's up pull entire pin out. Lift off plastic reach inside and turn bulb to unlock. Replace bulbs. Put triangle back on and simply push the pins back in place.
It is almost always the right rear lights that go first on these cars.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 08-11-2012, 01:02 PM   #7
Dentyneice
Just finished. The hardest part was getting those 3 plugs off that hold the plastic cover to the car.
Old 08-11-2012, 01:08 PM   #8
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
I have removed and replace many of those push pins, but on the camaro, they seem to break easily. Broke two of mine. Rarely do that on other cars.
Bonanza7 is offline   Reply With Quote
