05-07-2021, 09:52 PM | #1 |
ZL1 supercharger lid
Does anyone have any suggestions on how to clean the supercharger lid for the 2018 ZL1 Camaro? The car was a Florida vehicle and it looks like it has water spots on the lid.
05-07-2021, 10:08 PM | #2 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
You could try a 50/50 mix of water and vinegar let sit for a couple minutes and rinse, if that is not strong enough there are water spot removal products that are harsher. I always start simple and delicate then move up to stronger products.
2021 ZL1 1LE
Auto |
05-07-2021, 10:22 PM | #3 |
Thank you.
05-08-2021, 12:04 AM | #4 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Hey Nightfall, add some antifreeze to your top reservoir. It’s low!
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
05-08-2021, 12:17 AM | #5 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Maybe the reason for it being low is those "water spots" Maybe it isnt water
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-22-2023, 09:39 PM | #6 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Did you ever resolve this issue? I bought a used zl1 from Florida and have the same issue.
09-23-2023, 08:54 AM | #7 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
He's long gone. Last seen a year and a half ago.
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
09-23-2023, 09:43 AM | #8 |
Doh, haha ok thanks! I want to paint it, but don't know how to tape everything else off, so I'll try that vinegar idea.
01-17-2024, 03:44 PM | #9 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2024
01-17-2024, 03:54 PM | #10 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Try neverdull, It is awesome for aluminum. Read the directions and you will be good to go.
01-18-2024, 12:27 PM | #11 |
Heck yah, I'll try that, thankyou for the suggestion.
01-19-2024, 07:17 AM | #12 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
A more expensive option but one that will require significantly less work to maintain over the long run is to have the lid custom painted.
I bought a custom-painted lid from RPI Designs back in 2018. I just wipe it down after each wash. It looks just as good today as it did in 2018 when I installed it.
01-19-2024, 07:49 AM | #13 |
Drives: 2023 ZL1 M6 Riverside Blue Join Date: Nov 2008
Or chuck it completely >> https://www.mechanicalpower.net/shop...ercharger-lid/
The powdercoat I chose is a wrinkle finish and zero spotting.
** Sadly SOLD ** IBM 2SSRS Camaro M6... 2023 Riverside Blue ZL1 M6, 1 of 75
