11-19-2014, 07:39 AM | #1 |
M&H Racemasters
Got a set coming, what are you guys seeing for short times with this tire?
Do you know what it durometers at? Comparable to an Et Street?
11-19-2014, 09:54 AM | #2 |
Just checked them. durometer at 55 cold off the FedEx truck. How about short times guys? Burnout length, tire pressure to start?
11-19-2014, 10:59 AM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
The 325 17's? I just got a set too havent even mounted them yet
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
11-19-2014, 11:09 AM | #4 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Some of your answers may be listed on the 60' list, they call out which tire was used.
11-19-2014, 11:16 AM | #5 |
My 60' times were at 1.50 with my 18" M/Ts and dropped to 1.44s with the 17" M&H.
11-19-2014, 11:17 AM | #6 |
Drives: 2013 SS Join Date: May 2013
My buddy has been running them on his vette and had better luck with M/Ts ET 2s
11-19-2014, 12:20 PM | #7 |
Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
a local camaro here has been 1.41 he averages 1.43-46 runs 9.90's-10.0's
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146 |
11-19-2014, 01:36 PM | #8 | |
Perfect! Thank you.
12-09-2014, 08:29 PM | #9 |
Drives: '21 ZLE A10 Join Date: May 2012
M&H 325s are my older set of tires and they work well at 16psi. I have a 1.53 60' on them.
12-10-2014, 05:54 AM | #10 |
We have a customers car that has been 1.30
12-10-2014, 11:19 AM | #11 |
12-12-2014, 01:07 AM | #12 |
Drives: 2011camaro SS Join Date: Nov 2012
M&H are about the same as MT as far as how well they hook. I don't think 1 just outshines the other. You will here some guys with impressive 60ft times with both. And for the car that switched from 1 brand to the next, I wouldn't put to much weight in that Bc of the variables, different track prep, weather conditions, tire age. You can't go wrong with either brand. Almost comes down to Do you like a "T" or an "H" after your "M" lol
12-14-2014, 06:07 PM | #13 |
M6 9 second club
Drives: A 4000 Lb BeaSSt Join Date: Jul 2009
I hit a 1.4 60ft in my M6 with the M & H
Sent from J-Rod's Continuum Transfunctioner
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff #BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning Check out my youtube channel: http://www.youtube.com/user/6410Jrod Follow me on Instagram: @J_Rod6410 |
12-15-2014, 07:40 AM | #14 |
On Sat and Sun I pulled off a bunch of sub 1.4 60' with my M&H Racemaster DRs with a best of 1.369.
