11-25-2013, 06:48 AM | #1 |
New LFX M6 Nitrous Build - Info/Help Wanted
I have a '12 LFX M6 that I am looking to get better than SS numbers out of without dropping 7K+ on a twin turbo or supercharger. After looking at a few LFX Camaro Builds - Specifically ETMS183 I have decided that a Nitrous system is probably my best bet to keep the upgrades under 3K
I am not in a rush to make the upgrade, I want to get all my ducks lined up first and figure out exactly what and what not to do ---- so I am turning to Camaro5 for help. I have listed out a lot of questions that I have below. If you can answer any or all awesome! If you have anything to add that I am completely overlooking please post. Thanks everyone in advance! I am looking forward to beating some V8s As a final note, this car is a DD (Although I do have another car to drive while it is being worked on and I do most of my own work). With that said, I need to keep this car drive-able - I do not want it to be a track only car. My current performance mods include: Solo Mach-X exhaust (incorporated X-pipe) Solo HFCs Cold Air Inductions CAI Vmax Ported throttle body Apex Airscoop and washer bottle relocation kit 1. Probably the most obvious questions - which nitrous system? I am leaning most heavily toward the Ny-Trex Triple threat system but if there is another system I should consider please let me know. 2. Is a rear upgrade required? Obviously the stock 3.27 will blow up at a certain point but how much HP can I put into without concern? 3. If it is required - what goes into upgrading the rear? Is the 3.91 1LE gearing overkill for a V6? 4. And now for a very basic question How does the nitrous system work? (I am going to be researching into this but I figured someone could fill me in from your first hand experiences. some specific things I would like to know - how easy is it to install? Is it on (engaged) all the time? I know it is illegal outside of the track but say it were to be used on the street during normal everyday driving - does it only kick in at a certain RPM? Is there an on/off switch? 5. What sized shot should I be looking to use? 100? 125? 140? 5B. How long will an average sized can (fill in the blank) last using some of the above values? 5C. How much HP will each shot put out? 6. How far can I go without having to upgrade the clutch? 7. If a clutch upgrade is required, which should I go with? 8. How hard is it to get a good tune setup for daily driving with the nitrous system? 9. Are there any shops in the tri-state area that you would recommend for tuning the car? 10. Are rear suspension upgrades necessary (trailing arms and toe rods)? 11. I like my stock rims - yes I know they are ridiculous heavy but I like the look lol. Will the stock tires/rims hold up with hard launches from this system? 12. Upgrading the fuel pump - ZL1 pump seems the route of choice for this option, do we know what voltages need to be set to make this work? 13. Are there any upgrades or things to consider that I am overlooking? I'm not a street racer and the car is my DD - but my goal for my build is to be able to beat semi stock V8s off the line and go to the track every now and then to put down decent times. Any help and advice you can give me would be greatly appreciated! |
11-25-2013, 07:18 AM | #2 | |
Drives: Really Slow Join Date: Apr 2010
11-25-2013, 07:47 AM | #3 |
Thanks PoorMansCamaro! Much Appreciated! I have searched around trying to verify that the M6 has the same rear as the SS and have found conflicting reports - do you have a source I could verify this? I will try searching some more myself.
EDIT: Apex chase knows all as usual: http://www.camaro5.com/forums/showthread.php?t=187735 Last edited by cliffdog89; 11-25-2013 at 07:51 AM. Reason: Found the answer |
11-26-2013, 09:17 AM | #4 |
Drives: 2013, Camaro 2LS (BRM) Join Date: Jun 2013
Id say you guys hit it right on the head. The plugs have been a tough argument on some of the post, the best advice i can give at this point is to contact the different nitrous companys and ask their tech support, they are there for these questions. I personally also added fuel pressure safety switch, window switch, and a back to back nos solenoid to my system. Safety to myself and my investment is pretty important, but isnt required.
11-26-2013, 11:41 AM | #5 | |
Thanks - I definitely do not feel I can have too much safety with this system. Since I will be completely voiding my warranty I want to make sure this is as safe for the engine and car in general as possible.
11-26-2013, 12:41 PM | #6 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
On a previous vehicle I had a faulty throttle position sensor replaced even though my nitrous kit was wired up in plain site... heck still had my numbers on the windshield from the track and my helmet in the back seat... service writer even asked, "Why do you have a helmet in your car?" and gave me a knowing smile... replaced my TPS under warranty...
11-26-2013, 01:42 PM | #7 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
NGK = LTR7IX-11 plugs. Plug gap @.040" is what I run. Gap is something you may need to play with some, not every car likes the same thing. Low fuel pressure cutoff switch is a bare minimum safety MUST!!! NyTrex includes one in their kit. I'm sure Nitrous Outlet has one if it is not included in their kit.
11-27-2013, 07:51 AM | #8 | |
Thanks for all the info guys. I have a few more questions. So for safety I have so far: Window switch - what range do you guys use? 3K-6K? With this setup I am guessing you launch the car at 3K or do you launch at 2500 and let the nos kick in a split second later? Low fuel pressure cutoff. back to back solenoids. Some new questions I have from research. The Ny-Trex triple threat system says it is good up to 100HP - If I would want to go further - say 125HP can I do that with this system? Does the stock camaro rev limiter cut off fuel or ignition spark? If it cuts off fuel should I consider switching this out for a ignition cutoff to protect the engine if/when I hit the limiter? Should I remove the rev limiter through a tune or play it safe and keep it? Should I raise the rev limiter and if so to what level? I understand that for a manual I should also have a clutch switch so I am not feeding nos into the engine while shifting - do you guys have a recommended switch to use? This question is slightly unnecessary since I plan on tuning the car as soon as I install the nos system but prior to the tune is premium fuel necessary? With adding premium fuel and nos into the system how much timing retardation is necessary to avoid knocking? Having the two tunes (track vs street) - how quickly can these be swapped between? Do I just need to have a laptop in the car and switch between the two? Is it possible to tie the tune to the NOS on/off switch so that both are loaded on the ICU and only one is activated at any given time? Does the Ny-Trex kit include a remote bottle opener? If not, which would you guys recommend? What bottle heater would you suggest? is it safe to install the bottle and bottle heater in the spare tire well? How do you guys route the nos from the rear of the car to the front? Are these components included with the Ny-Trex kit? |
11-27-2013, 10:13 AM | #9 | |
Drives: Fast! Join Date: Mar 2013
11-27-2013, 10:36 AM | #10 | |
11-27-2013, 11:43 AM | #11 | |
your 225 rating - is that to the wheels or at the crank? I am probably not looking to exceed a 125 shot but I would like the flexibility to go past the 100HP point. Anything past 125 and I feel I will need to upgrade a lot more on the car than I want to - at least right now. I like the bracket - but I think I will be going for more of a stealth install for my system. I will definitely be adding a wide band monitor to monitor the system so thanks for the tip! Once I have some more information collected I will be contacting several nos system suppliers to determine which system I want to go with. Thanks for your input! |
11-27-2013, 12:06 PM | #12 |
another question - I would like to go with a dual gauge in cabin setup - probably mounted on the driver side window support (I can't remember the technical name lol). One for the fuel/air ration and the second for the pressure on the nos bottle. I am going to mount the nos canister in my trunk and would like a way to monitor the pressure remotely. Is there a simple way to do this?
11-27-2013, 01:06 PM | #13 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
Pillar gauge pod, Autometer makes a dual one. I have it along with a wideband and boost gauge. Wideband is a must if you do boost or nitrous.
11-27-2013, 01:42 PM | #14 |
Drives: 03 vette, 94 trans am, 04 gto Join Date: Jul 2012
I know you have had a lot of your questions answered already but feel free to pm or email me with any other questions. We only sell nitrous outlet products and do so many kits it's not even funny Currently we have the 15% off sale going on for nitrous outlet products also
