02-23-2015, 02:04 PM | #1 |
Drives: 2012 Chevy Camaro RS Join Date: Jun 2012
Reference on Strut Tower Braces
I am in the market on purchasing a strut tower brace for a 2012 Camro V6. I've looked over different websites. A few reviews I've read they have received their braces with scratches and/or without the hardware to install the braces.
Can anyone help me and guide me to the correct one for my V6 also which on has the best improvement on the handling. Thank you an advance. |
02-23-2015, 02:12 PM | #2 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
To be honest, installing a STB isn't going to help a whole lot in the handling department. I've left mine off before, even on my Vert that has a factory one, and it didn't make a noticeable difference.
02-24-2015, 12:46 AM | #3 |
I run 2 catch cans...
For a bit more money, you can have a ZL1 or 1LE front sway bar and end links installed. You can then corner about 2x as fast as you probably do now.
Overkill tuned Air Scoop CAI VMAX PTB JacFab Laminator FX + Extendolator SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . |
02-24-2015, 10:00 PM | #4 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Ok, maybe not, but if you try to corner 2x faster and all you have done is put a front sway bar on your car it will push more than it does stock. Your suspension is a balanced system. you cant change just one component and expect it to work as a system. Bad advice above!
02-26-2015, 12:32 PM | #5 | |
Feel free to call, PM or email me anytime with questions. Best regards, Tyler 888-308-6007 |
02-26-2015, 01:00 PM | #6 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
I had no noticeable difference with my STB (Pfadt). I had no intention of getting one, but one popped up on Camaro5 for a good price so I jumped on it.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
02-26-2015, 11:08 PM | #7 |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
I don't have a STB on my 2011 SS. I've considered getting one because the ZL1, Z/28, and 1LE have factory STB's. They are all designed with handling in mind. The STB must have some influence on handling or GM wouldn't have it from the factory.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
02-26-2015, 11:28 PM | #8 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
Bmr STB for V6. Can't say what it added as I had the whole BMR level 2 suspension package put on at the same time.
03-01-2015, 11:19 AM | #9 |
Here's the 1LE on my 2012 1LT. More for looks than handling.
