01-23-2011, 03:08 PM | #1 |
Tattooed K9
Drives: E63AMG Join Date: Jan 2011
Real World Suspension Setup (Not Track)
Ok Folks,
I have been talking with Apex Chase and I am going to have him put a package together for me. But before I do any suspension modifications I want to ask, in reality (meaning real world street driving) what modifications are really going to improve the handling capabilities of the SS without going overboard? I already had a Vette ZO6 that had an aftermarket track suspension on it, and to be honest it hurt the car more than it helped it. Driving it on public roads was so stiff and harsh that hitting a bump would literally make the car jump. That's not good on real public roads that aren't smooth like a track. At times in the car modification circles people tend to go way overboard with 800 RWHP cars running race suspensions. That basically creates a useless car that has to be babied all the time. I don't want to repeat ZO6 experience. So, I am thinking about the Pfadt coil overs to start. Do I need to go with sway bars as well to balance the Camaro? The more I think about this, the car is going to be 100% for street driving. Regards, John |
01-23-2011, 03:26 PM | #2 |
John, it has been good talking with you and I look forward to doing business with you. Sway bars are a must, even for 100% street applications, when it come to these cars. A good set of sway bars will reduce body roll and understeer by increasing rear roll resistance and bring more balance to the overall feel of the cars handling. Another weak link in these car's stock suspension is the mushy rear cradle bushings. Upgrading those reduces rear end step out and creates a more predictable and controlled feel, especially under heavy throttle.
01-23-2011, 03:37 PM | #3 |
GM Millwright
Drives: 2011 Camaro 2SS/RS M6, Lingenfelter Join Date: Aug 2010
Apex could you be good enough to post up all the recommended parts, I'm in the same boat, car is going to Lingenfelter on Wed. for the engine work and next thing on my mind is a "real world " suspension upgrade for a car that is never going to see a track. I'm looking for a good handling car without it being harsh. thanks
01-23-2011, 04:03 PM | #4 | |
01-23-2011, 05:13 PM | #5 |
Dances With Mustangs
If you're never going to track your car, then I'd suggest a mix of Pedders and Pfadt mods. Pedders bushings are designed to be street mods that can be used on the track, whereas Pfadt is specifically designed for track racing and priced accordingly.
As a minimum I'd recommend Pedders rear bushings, and Pfadt sport sway bars front and rear including their endlinks. If you want to go beyond that then there are several things that are beneficial. Coilovers are great for lowering the car without compromising ride quality. I'd recommend Pedders Xa coilovers. Replacing the rear trailing arms makes a noticeable difference in calming down the rear suspension under acceleration and eliminating wheel hop. I'd go with Pfadt rear trailing arms. Although somewhat pricey, I'd highly recommend RacingBrake 2-piece brake rotors for their reduction of about 6 lbs each of unsprung weight which improves the cars performance in many ways besides braking because of the weight reduction. I'd also change to braided stainless steel brake lines too which improve braking and give a much better feel to the pedal when braking. There are other things you can do besides these things of course but just doing the above will give you a seriously respectable street machine.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
01-23-2011, 05:30 PM | #6 |
Drives: 1968 Bronco,2001 Fatboy,2010 SS Join Date: Jan 2010
Real world..... Sport sway bars and endlinks and drop springs. same your money on the coilovers.
I went with Pfadt for my brand because I called to speak with them twice and Aaron (the owner) answered the phone both times. There is just something about a owner, who does not have to answer the phone, who answers then phone. He was just an honest guy who told me that a "Off Track" car does not need much and most of the other parts that you can buy you would never even notice. I am not a race car driver, nor a weekend track guy, nor have I had a bunch of newer expensive cars with better handling. I drive a Fire Truck at work and have built a few muscle cars in the day. I noticed a difference on the on and off ramps, general cornering, and highway emergency reactions with these mods. I hope this helps, Bill Baranowski |
01-23-2011, 07:00 PM | #7 |
"Camaro Joe"
pedders cradle and radius rod bushings and soultions b sway bar package is all you need tighten up the car but keep the suspension nice and firm but not harsh. if you want to add lowering go with the pedders xa coil overs
01-23-2011, 08:58 PM | #8 |
Tattooed K9
Chase,
I'll plan to stick with the list that you send me when I am ready to go. I'll ready out to you and order within the next 90 days. Tony's Corvette in Gaithersburg is going to install it all for me. John |
01-24-2011, 08:35 AM | #9 |
Drives: 2010 1SS Join Date: Jan 2010
Springs, sway bars, and bushings. These 3 parts alone will wake the car up without destroying your ride (as long as you don't go crazy with springs). Then, if you have wheel hop, a set of Trailing Arms. These parts should be done to every new Camaro, V6 or V8, whether it is just a stock daily driver, weekend track car, or cruiser...
Apex Chase can vouch for the value of our Suspension Packages. I am sure his recommendations match what I have listed and if you choose BMR, our matched packages can save you some green... |
01-24-2011, 05:35 PM | #10 |
01-24-2011, 05:55 PM | #11 |
Drives: 2010 SS/RS Join Date: Jun 2010
Sway bars definately. Drop springs Im not sold on yet. Ive had them in for about a month and mine is my daily driver. Unless youre on smooth highway pavement the ride is noticably worse. I drove for a few days with just the sway bar swap and it really is a night and day difference. Then I added the drop springs and I will honestly say they do not inspire confidence if your cornering on anything other than very smooth road surfaces.
Personally I am considering adding the trailing arms and end links or pulling them back off and going with the coilovers. I may get some differing opinions on this but my opinion is that the sway bars are a perfomance mod and drop springs are mostly a visual mod |
01-24-2011, 09:53 PM | #12 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Just the way it is. |
01-24-2011, 10:09 PM | #13 | |
Drives: 2010 rs ss Join Date: Jan 2010
01-25-2011, 07:53 AM | #14 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
What springs did you use and did you do the bushing timing during the alignment? Just wondering. I just ordered the BMR level 1 and I also worry about ride quality!
Similar Threads | ||||
Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 02:18 PM |
The Official Camaro5 Fest II Track Assault By Pfadt Race Engineering | PfadtRacing | Suspension / Chassis / Brakes | 466 | 09-16-2011 11:57 AM |
Real world MPG from real drivers...... | Silverado | 5th Gen Camaro SS LS LT General Discussions | 60 | 06-26-2009 09:01 AM |
Real world fuel economy expectation for L99/LS3? | Scotsman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 09-21-2008 09:50 PM |
World History Lesson | TAG UR IT | Off-topic Discussions | 2 | 06-21-2007 02:56 AM |
