View Poll Results: What sounds better? | |||
Stock exhaust | 3 | 16.67% | |
Stock exhaust with muffler delete | 6 | 33.33% | |
V8 exhaust | 6 | 33.33% | |
V8 exhaust with muffler delete | 3 | 16.67% | |
Voters: 18. You may not vote on this poll |
Thread Tools |
09-17-2014, 08:59 PM | #1 |
Drives: 2017 A10 ZL1 Join Date: Apr 2013
What do you Guys like better?
Im curious to what you guys think sounds better. Keep In mind these exhausts will be on a 2012 lfx engine.
See poll above |
09-17-2014, 09:24 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Depends. 2.5" magnaflow resonated x pipe with 2.5" straight pipes sounds the best IMO.
09-17-2014, 09:26 PM | #3 |
Id rather not spend any money on stuff i have to order. I already have both a v6 and v8 exhaust and the materials to do a muffler delete so thats what i want to stick to.
09-17-2014, 09:28 PM | #4 |
Just a muffler delete will sound raspy. V8 exhaust is your best bet currently I think. It certainly flows better and would sound better.
If you can manage an extra $100ish I would seriously consider the magnaflow resonated x with the SS exhaust.
09-17-2014, 10:12 PM | #5 |
I have MagnaFlow X over cat back.....I love the way it sounds....deep rumble...
09-17-2014, 10:14 PM | #6 |
Mrt v2 and magnaflow resonated x pipe
09-17-2014, 10:33 PM | #7 |
I appreciate the suggestions but i don't have any money for it right now so if you had to pick one of the poll options what would you choose.
09-17-2014, 10:43 PM | #8 |
Try the SS exhaust for now.
09-17-2014, 10:44 PM | #9 |
09-17-2014, 11:37 PM | #10 |
KaBoom1701
NPP Dual mode exhaust!
Mods:
09-18-2014, 06:43 AM | #11 |
i have muffler delete with magnaflow resonated x-pipe and stock resonators, using the stock v6 exhaust. no matter which exhaust you use (v6,v8) it will sound raspy when you cut the mufflers off. if you do cut the mufflers off you will want to run new pipe out to the back of the car.
09-18-2014, 09:30 AM | #12 |
I would love to buy those different pipes but I don't want to spend the money right now.
09-18-2014, 10:28 AM | #13 |
Like stated before, you have the best sound you're going to get. Muffler delete with either system will sound raspy as hell without a resonated x pipe.
09-18-2014, 10:30 AM | #14 |
So do you guys agree that if i was to do a muffler delete on the v8 exhaust then i should also buy the resonated x pipe
