09-04-2009, 10:47 AM | #1 |
Scout Sniping
anyone hear this?
When in reverse sometimes I hear this grinding sound when I apply the brakes. Not all the time, only at random times. Anyone else? Also when going from a dead stop a pulsating sound when going forward.....
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!! Now I drive a F150 Supercrew |
09-04-2009, 10:49 AM | #2 |
Booooosted.
Sometimes, overnight rust can cause this when backing out of the driveway. I hear it in the morning but usually not the rest of the day.
09-04-2009, 10:50 AM | #3 |
Scout Sniping
the sound both times is coming from the middle of the car
Eric
09-04-2009, 10:58 AM | #4 |
Booooosted.
Is it loud. Soul=nd like you could even hear it if you were outside the car?
09-04-2009, 11:24 AM | #5 |
Scout Sniping
not sure, its sounds like when i break im scraping the ground
Eric
09-04-2009, 11:27 AM | #6 |
Booooosted.
I know that on my Jeep, I had worn my pads down to the metal (I know) but the rotors got mared up and the sound sounded like it was coming from underneath. Now obviously your pads and rotors aren't worn but could still be in the system. But sounds to me like you better get under there and see if you have any visible thing going on and I'd get it to the dealer. That's not normal. |
09-04-2009, 11:31 AM | #7 |
Okie doke
09-04-2009, 11:33 AM | #8 | |
Drives: 2006 Hummer H2 2010 2SS Camaro Join Date: Jun 2009
09-04-2009, 11:41 AM | #9 | |
Booooosted.
Ya, either way, I'd damn sure be visibly looking under the car AND taking it to the dealer. |
09-04-2009, 12:10 PM | #10 |
Scout Sniping
well i was just underneath it about 2 hours ago (tightening MBRP Pipes) and there is no problems that I can see.
Eric
09-04-2009, 12:53 PM | #11 |
Drives: IOM 2010 - 2SS/RS Join Date: Nov 2008
I have heard this a few times backing out of the garage in the monring. I was assuming it was rust on the rotors as well. That is the only time I hear it. Let me know if you find out anything from the dealer.
2010 2SS/RS IOM Upgrades: Fastlane CAI / SLP II Loudmouth axle back / V Max Ported TB / Kook's Step Long Tube Headers / High flow cats / Straightline Tune / BMR front & rear sway bars / Hotchkin End Links / Hurst Short Throw. LG ZR28 Wheels 1 of 2 sets made. Pfadt trailing arms / Diff Bushings & Sub Frame bushings / 1LE Axle & Hubs.
09-04-2009, 01:24 PM | #12 |
Drives: Everywhere Join Date: Jun 2008
It is most likely your rear brakes. They can take a long time to seat properly and will often times make a scrubbing noise when new. This is more common on performance brakes such as yours. Alternatively, I have had the exact same symptoms from a worn out u-joint. However it was on my parents 2001 Suburban after they had clocked 75k+ miles. One of the bearing caps had run dry and was rusted inside. Very unlikely on a new car but still a possibility.
09-04-2009, 01:25 PM | #13 |
Shadow Gray '19 ZLE M6
I hear it often too. The scenario is usually backing out of an inclined driveway. If I gas it a lil bit and then hit the brakes (so I'm rolling in reverse) I hear that "scraping" sound. I have no idea what it is.
2019 ZL1 1LE | M6 | SGM | PDR | CF Dash | Nav | Wheel Locks
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
09-04-2009, 10:18 PM | #14 |
Scout Sniping
these all sound like the same instance......
Eric
Similar Threads | ||||
2 SS 451 miles in 8 days I can't stop I hear the call | yesno20102ssblack | 5th Gen Camaro SS LS LT General Discussions | 19 | 05-11-2009 07:48 AM |
Let me hear yern's! | 7CAMARO7 | 4th Generation Camaros | 3 | 04-08-2009 03:31 PM |
Didn't hear from dealer today, did anyone? | Rob53 | 5th Gen Camaro SS LS LT General Discussions | 4 | 02-20-2009 07:16 AM |
Now hear this: | fbodfather | 5th Gen Camaro SS LS LT General Discussions | 69 | 04-03-2008 05:22 PM |
hear ye hear ye | WillInThe04Ranger | Off-topic Discussions | 32 | 02-27-2008 11:14 PM |
