06-04-2012, 06:10 PM | #1 |
Don't ask to pop my hood!
Drives: it's loud....... Join Date: Jun 2011
Sea Foam Question...
OReilly has it on sale for $7.99 Sea Foam Motor Treatment, the bottle is white with red writing says for auto,marine,fleet is this the correct one?
Also my car has 30,000 on it would i benifit anything from adding this? Thanks..
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS | 2010. |
06-04-2012, 07:14 PM | #2 |
Drives: White M6 1LT RS Join Date: Mar 2010
Buy the aerosol can that goes into the throttle body. It's new and much better at delivering the product where it needs to go.
It might clean up the oil sludge buildup on the valves.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
06-04-2012, 09:38 PM | #3 |
Would i still need to clean my injectors? and will have to change my oil? with this process using aerosol
