04-06-2019, 01:27 PM | #1 |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
Wheel and Tire Size after 4.10 Gears
Hi all,
I have a 2014 SS 1LE, I will be doing a full car build soon to really make this car shine on the road course. I have decided on going with an eaton truetrac + 4.10 gears for the differential. I was going to stick with my factory 20" wheels and similar tire sizes, but I am considering dropping down to a 19". Will the more aggressive gearing (4.10 from 3.91) plus the tire size drop (going from a 295/35/20 to a 305/30/19) negatively effect me? Am I better off staying with a 20" wheel while I have the 4.10's for now? This is a street and track car.
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP -Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing |
04-07-2019, 08:00 AM | #2 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Any straight where you're getting closer than that to your shift point now, you'll be upshifting before that corner. If you're not using 2nd very much now, you may use it even less frequently. But there's a bit of track-specificness involved - you could, for example, find the new overall setup puts you a lot closer to redline down one or more of the longer/faster straights than you're currently able to reach, without having to grab that "one-higher" gear. And any corner where the same gear is still usable will, of course, give you stronger acceleration on exit. FWIW, it cost me at least one extra upshift and one extra downshift on both of the courses at my home track, with the only change being a tire diameter change from about 27.1" diameter down to about 25.9" (4.5% fewer mph, shifting at the same rpm). I completely understand having a few uncertainties about this, since I've been mulling over the plusses and the minuses of a couple of powertrain mods myself. In a whole lot more detail than I've provided above. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
04-07-2019, 02:46 PM | #3 | |
Engineer
It does seem like my 2nd, 3rd, and 4th gearing would be better than the extremely tall tires, right now in most cases im in the middle of my gears so this should in theory stick me higher in my powerband. Definitely might be one of those cases where you try it and see what happens. To my surprise it seems like i'd actually get better street mpg (in theory) because i'd be turning just over 1300 RPM in 6th going 46mph. Might lose a few on the freeway though.
04-07-2019, 05:01 PM | #4 | |||
Something else to consider . . . you generally lose a mph or two when you have to upshift at 120 or so, and it takes a finite amount of time and remaining straight length to recover the scrap of lap time it cost you. Quote:
Norm
