Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 07-20-2019, 10:31 AM   #1
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Front Control Arms
I'm trying to order Z28 front control arms for my SS. I'm building it as a dedicated track car so I want the best parts I can get for the suspension.
I ordered part numbers 23105014, 23105015, 23105018, & 21305019.
According to the casting numbers on the control arms it appears I got 92236898, 92236899, 20951300, & 20951301. The bushings on these have spaces in the bushings, I assume to soften the ride.
Can anyone tell me, or post a picture, if the Z28 control arms have the spaces?
My understanding is the only difference between the SS & Z28 control arms is the bushings.
I just want make sure I'm getting the correct parts before a raise a ruckus with Rock Auto.
Thanks Craig
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 07-21-2019, 03:52 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The lower control arm should have a white/tan insert in the bushings so you shouldn't see a void but the radius arm shouldn't have anything if I remember correctly.
Orange Krush II
Old 08-05-2019, 06:07 PM   #3
SS Performance
I want to thank everyone that helped me out.
I think they are the Z28 control arms. It was a bit confusing the Z28 forward arms have a whitish center piece. The arms that cam off the car had similar color center pieces. The difference was the hardness.
Thanks again.
Craig
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
2008 HHR SS
