05-18-2014, 10:07 AM | #1 |
redleader
ABL ? on a 2009 LLT V6
I was taking my doors apart to fit new wing mirrors and saw these:
Now, I did not think my 2009/2010 V6 1LT LLT had wiring for an ABL upgrade? Or are these sockets for something else? |
05-18-2014, 10:18 AM | #2 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
That's a 2010 1LT built in 2009.
From what I have heard the early 2010 builds all had the abl wire in the door. I have a 1SS and the plug is in there.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
05-18-2014, 02:07 PM | #3 |
redleader
Thanks PAUL SS
Might there be a plug for the Dash strip too ! :-) |
05-18-2014, 02:12 PM | #4 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
yup that's ABL.
pop the cover for the fuses on the driver side there should be one there and then one under the speedo cluster as well. |
05-18-2014, 05:22 PM | #5 |
redleader
Oooooo where do I buy the tubes, pipes, LEDs?
Thanks, |
05-18-2014, 05:34 PM | #6 |
I have the blue lights for the doors but no tubes if you are interested.
05-18-2014, 08:01 PM | #7 |
KNGTFALL
SJM has all the parts needed
http://sjmap.corecommerce.com/Door-ABL-Pipes-Top.html I believe a competent dealer need to turn on the function of the ABL, but I am not sure. on mine I already had ABL, I added the 2nd LED to the door and the full dash ABL kit from SJM. Combined with the NightOwl modules with RGB LEDs |
05-18-2014, 08:20 PM | #8 |
Ride On!!!!
^^^yeh, he knows.
05-19-2014, 12:38 PM | #9 |
Drives: '16 2SS Join Date: Apr 2011
The dealer should be able to update the BCM to activate the ABL lines, but, some are refusing to do it.
05-19-2014, 01:05 PM | #10 |
redleader
05-19-2014, 01:10 PM | #11 |
ya all earlier models have it, but 1lt doesnt have it programmed, my dealer refused to programmed it so i had to tap it to windows switch.
05-19-2014, 01:14 PM | #12 |
Yes. Window-switch lighting wire is the easy fix.
05-19-2014, 01:26 PM | #13 |
Ride On!!!!
You might want to try gen5diy.
There are ways to get programming done.
05-19-2014, 01:49 PM | #14 |
redleader
I was looking at Gen5DIY earlier Guys.
Thanks for your help and chat :-) If there is a Post tutorial let me know, meantime I will contact Gen5 for advice too. Cheers! |
