03-04-2015, 12:06 PM | #1 |
Drives: 2022 SS 1LE Join Date: Jul 2013
"Orange Crush" 2013 Camaro Track Car
If you are a Camaro guy, this is the ultimate track/street build. Still with full interior and AC, it can be driven to the track with comfort. It can then be tracked safely with a custom welded roll bar, Sparco seats and a six point harness. This is a new build. It's been tracked only three times since the new forged 514 RWHP / 478 RW Ft-Lb engine, Quarter Master billet clutch, DSS 1,000 HP Axles and dual oil coolers were installed.
Lap times: -Buttonwillow Raceway 13CW: 1:53.4 seconds (beat production car record of 1:55.7 held by Viper ACR) -Thunderhill 5-mile: 3:30 seconds It is ideally suited as a fun weekend track car, or can compete. It's Weight:HP is ideal for NASA TT2. Or cage it and run it in NASA ST2, American Supercars, or other series in SCCA or NASA. BUILD DETAILS: 416 c.i. all-forged LS3 stroker with all the goodies, built by Synergy Motorsports Trick Flow Heads, with hollow stem exhaust valves, match-ported with Fast Intake Brian Tooley custom grind cam with gentle lobe slopes for the road course. Designed for max torque and to roll off HP to keep me in NASA ST2 class. 514 RWHP, 498 RW Ft-Lb on 91 octane Improved Racing Oil Pan Baffle Pedders Supercar Coilovers, double-adjustable Lots of bushings upgraded Pedders 32mm rear sway bar APR wing and splitter DSS 1,000 HP Axles, with upgraded boots that don't tear with lowered Camaros Dual oil coolers, custom-shrouded to take high-pressure air to the left and right of radiator. Runs cool even on blistering hot track days. ZL1/CTS-V 6-piston front brakes, 2-piece rotors (one track day on these- brand new) Quarter Master Optimum SR Two-Disc Clutch, rated at 1,400 HP / 1,000 Ft-Lb (used in Grand Am Z/28s) Slave cylinder upgraded with billet steel bearing housing Roll bar, custom from Tracklogic Full interior, custom carpet, still has A/C, satellite radio. Great to drive to and from track. Sparco Evo and Evo II seats Sparco 6-point harness CCW forged wheels, 18 x 11 front and 18 x 12 rear, 315s front and rear with no rubbing Also includes stock 1LE wheels and nearly new BFG Rivals 285/35-20 $49,000 Todd (408) 391-1379 solomontodd@yahoo.com
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
03-04-2015, 12:08 PM | #2 |
A few more pics of the beast on track...
03-04-2015, 12:49 PM | #3 |
KaBoom1701
Onto your next adventure?
Mods:
03-04-2015, 12:55 PM | #4 |
What wing is that?
03-04-2015, 12:55 PM | #5 |
Sadly moving to a slower car that I can afford to race all season. It's a Spec Mustang with a stock 4.6L engine and drivetrain. Inexpensive to run and repair, not nearly the beast that the Camaro is.
03-04-2015, 12:57 PM | #6 |
It's an APR GT-250 wing. Very efficient, adjustable, plenty of downforce and balances well with the APR splitter.
03-04-2015, 09:06 PM | #7 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
Todd is leaving us . I really enjoyed your on track footage.
03-04-2015, 09:51 PM | #8 |
Drives: 06 Z06 Join Date: Feb 2014
good luck with the sale. I saw it at Synergy when I was picking up my Z06 a week or 2 ago. I hope you have fun out there in the series.
03-04-2015, 10:11 PM | #9 |
Drives: 2014 Summit White 1LE Join Date: Sep 2013
Epic build man! Your car is awesome, hope it finds a good home
03-05-2015, 11:49 AM | #10 |
Drives: 2010 2SS Join Date: Sep 2012
I guess no oil cooler write up :( will miss your posts for sure.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
03-06-2015, 11:44 AM | #11 | ||
Thanks gents! I'm hoping a track rat will pick it up and show what a Camaro can do.
03-06-2015, 11:45 AM | #12 |
Man, I wanna write it up. I'm so freakin busy but I will try. A lot going on prepping for racing season.
03-06-2015, 12:21 PM | #13 |
even a parts list and a few general pics would be nice. i can figure it out
03-06-2015, 04:53 PM | #14 | |
KaBoom1701
How much were you having to dump into the car per race or track season? Just curious.
Mods:
Thread Tools | |
