Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 06-14-2014, 02:09 AM   #1
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
2015 1LE vs 2003 Silverado SS w/ Whipple
My friend has a 2003 Silverado SS, and is getting a Whipple by the end of the year. He thinks he'll be able to beat my 1LE. The truck stock does 0-60 ~6.8 seconds with a 1/4 mile close to 15 seconds. I highly doubt the Whipple will drop his 1/4 mile by 3 seconds. My 1LE will be mostly stock, just VMAX TB and CAI intake. We have a $500 bet on it. I think I have this no problem, but he thinks he'll walk me. What do you guys think?
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 06-14-2014, 03:06 AM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Just depends what other things he might get done my denali Crewcab ran 11.70s with boost. I think he will get close to it IMO.
62nalide is offline   Reply With Quote
Old 06-14-2014, 07:37 PM   #3
2011shelby
Drives: 2011ShelbyGT500
Your going to destroy him unless he has major mods done at the same time.
Basic Whipple kit MIGHT put him in the high 13's.
2011shelby is offline   Reply With Quote
Old 06-15-2014, 06:53 PM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
Most will see mid 12s
Old 06-15-2014, 07:08 PM   #5
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
Trucks can be strange ducks. I've seen some that sound and look super fast only to disappoint and some that look total stock only to scream.
alaskacamaro is offline   Reply With Quote
Old 06-15-2014, 10:25 PM   #6
legacy
Drives: 2013 Camaro 2SS
if hes that confident, hes probably getting other stuff done as well...might want to consider adding headers or something as insurance.
2013 L99
bolt ons, tune
legacy is offline   Reply With Quote
Old 06-16-2014, 06:47 AM   #7
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
A now defunct company in MI called Wheel to Wheel had a Silverado SS that had a turbo or blower on it. (cant remember).....It went door to door with my Evo 8 that would run 11.3 @ 122.
Matt
Old 06-17-2014, 02:41 AM   #8
damian559
damian559's Avatar
His truck is completely stock, and all he is adding is the Whipple, no supporting mods at all. There's no way he's taking 3 seconds off his 1/4 mile time.
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 06-19-2014, 01:53 AM   #9
KTMracing09
KTMracing09's Avatar
Drives: 2SS/RS L99 ABM
Get a set of long tubes as stated before. You'll love them! Then once you win take that $500 and consider it a set of long tubes for practicality $200, considering most run around $700
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
KTMracing09 is offline   Reply With Quote
Old 06-19-2014, 08:55 AM   #10
OK2DRUL
ace5.org (Atlanta Club)
OK2DRUL's Avatar
Drives: 2010 Black/IOM 2SS LS3
That all wheel drive truck is going to launch and hold traction pretty well, regardless of the weight and they respond well to boost. The 1LE is a road course car and not a drag car, with most 1/4 mile stock times being slower than a regular SS. Should be a good race, but most people aren't running sub 13s in these cars without a driver mod. Not sure of your experience and how much track time you'll have in your car before the race, but should be a good one. Make sure to post videos of the results!
OK2DRUL is offline   Reply With Quote
Old 06-22-2014, 01:47 PM   #11
damian559
damian559's Avatar
Well I'm going to get LT headers and a tune before the race. It shouldn't be a problem now.
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 06-22-2014, 02:37 PM   #12
alaskacamaro
If ALL he did was add a supercharger, you should have no problems, especially if you tune and add LHT.
He has 345 crank hp stock. If he is an auto, he'll weigh a few hundred pounds more than you. He will have 450 crank or more depending on the setup..
Adding your mods should put you around 430-440 whp (I have seen a few stock 1LE's put 390-400). Of course, your not built for drag racing but you should still do well.
Old 06-22-2014, 02:44 PM   #13
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
An extended cab/regular bed Silverado 1/2 ton weighs quite a bit more than a few hundred pounds over a Camaro, it's a more like another 1300 lbs.
The Silverado SS would need more than a supercharger to keep up.
CamaroTom is offline   Reply With Quote
Old 06-22-2014, 02:49 PM   #14
alaskacamaro
Originally Posted by 1LEMayhem View Post
An extended cab/regular bed Silverado 1/2 ton weighs quite a but more than a few hundred pounds over a Camaro, it's a more like another 1300 lbs.
I'm assuming he was referring to the 1500 series SS (curb approximately 4000 lbs). If it is a larger series than the truck will have an even greater power/weight ratio disadvantage.
Some trucks are absolute monsters at the strip. Some just sound really loud, which for some reason makes the owner add 300 more "simulated" hp.
