Old 04-24-2017, 08:27 PM   #1
ARCTIC
ARCTIC's Avatar
Drives: 2017 1SS convertible
Splash guards?
Has anyone put splash guards on their car? I will have to frequently drive a short distance on a gravel road and was thinking splash guards might be a good idea. My wife is not keen to the idea. I tried to explain that they weren't going to be big gawdy ones but anyway. Can someone post up some pics of your fancy camaro with splash guards? Where did you get them and what does it take to install?
Thanks!
ARCTIC is offline   Reply With Quote
Old 04-24-2017, 09:23 PM   #2
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Here is a few options, opinions and some pics.
http://www.camaro5.com/forums/showthread.php?t=483388
witenite is offline   Reply With Quote
Old 04-24-2017, 09:27 PM   #3
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
I installed these, https://www.rpidesigns.com/shop/item.aspx?itemid=3303 very simple install. I added a few extra screws but that is just me. Hope this helps. Rpi designs is vendor for the forum
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 04-24-2017, 09:33 PM   #4
Stewart
Stewart's Avatar
Here they are installed on my car
Old 04-24-2017, 09:47 PM   #5
ARCTIC
ARCTIC's Avatar
Thank you for that link!
Those were the ones I found on a google search. Did you do the premium (extra thick) or the standard ones? I was going to order weather tech floor liners from them as well.
Old 04-24-2017, 11:17 PM   #6
seanjhon
seanjhon's Avatar
Drives: 2013 camaro
I installed the extreme racing front splash guards
Here:
http://www.xtremercracing.com/Produc...30026&pID=1601
And got some rear zl1 splash guards from Maureen here on the site from rogers Chevrolet. Great look
Feel free to pm for questions
seanjhon is offline   Reply With Quote
Old 04-25-2017, 12:11 AM   #7
samgray20
samgray20's Avatar
Drives: 2010 CGM 2SS/RS M6
+1 on RPI. They do wonders on this gravel driveway and country back roads. The front ones look great, but I did do a little extra securing with double sided tape to make them look a little cleaner. However, spend the extra money and go for the zl1 rears. I tried the cheap rear ones and they just didn't do it for me. They had excellent service and helped get me straightened out with the product I wanted.
Sent from my SM-N920V using Tapatalk
2010 CGM 2SS/RS M6 - Comp 227/243 .620/.612 | Nitrous Outlet Plate Kit - 100 Shot | ARC Bottle Bracket/Heater | NOS Progressive Controller | AEM Wideband | Kooks 2"x3" LTs | 3" Custom Catback | CAI Intake | Bo White PTB | Billet Motor Mounts | Hurst Short Throw | McLeod RXT | RAM TOB | 3.91 W/ Eaton Truetrac, LPW Cover, Poly Bushings, GForce 850HP Axles | Eibach Pro-Plus Kit | Whiteline End Links | Hotchkis Tower Brace | ZL1 Front End | Blue Powder Coated Calipers | Vorsteiner V-FF 101 - 20x11 and 20x10 | M/T Street Comp - 305/35 and 275/40 | 2 JL Amps | Diamond Audio Speakers | JL Stealthbox
samgray20 is offline   Reply With Quote
Old 04-25-2017, 06:46 AM   #8
Stewart
Stewart's Avatar
I got the thicker ones. As samgray20 said I thought they would hold up better, in which they are.
Old 04-25-2017, 07:53 AM   #9
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
WOW! I saw this thread and did a search. I found a set of these on Amazon for only only $70! I pulled the trigger immediately. What a snag, doing my happy dance.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 04-25-2017, 09:43 AM   #10
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I just installed these, subtle and get the job done well
https://zl1addons.com/collections/rockguards
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 04-25-2017, 10:00 AM   #11
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
I have the ZL1 fronts only as shown above. Very happy with them. Minimalist design that's barely noticeable and definitely prevent rocks from flying down the side of the car. Don't believe the rear ones are necessary in my opinion. Very easy to install as well.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 04-25-2017, 12:19 PM   #12
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
I have this combo pack of Zl1 rears with flat splash front. Happy with it.
https://www.rpidesigns.com/shop/item.aspx?itemid=2271
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 04-25-2017, 01:00 PM   #13
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Originally Posted by samgray20 View Post
+1 on RPI. However, spend the extra money and go for the zl1 rears.
x2, I'm running the RPI fronts with ZL1 rears on my car as well.
Can barely even notice them on the car from a distance:
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
