Old 10-17-2017, 04:32 PM   #1
l.abrego
l.abrego's Avatar
Drives: 2015 summit white Camaro
Headlights
I posted this elsewhere but this seems to get the most traffic and I need help with some headlights. Alright so I purchased these headlights off someone here which are the U shaped headlights for the non rs 14-15 Camaro. The halogen will not turn on for either side. What can it be. The U shaped rings turn on when fed a source of power but the center halogens just wont work. Thanks. He also claimed they were knew and never used before but oh well I guess I got scammed. But im still trying to see how I can make them work or if it’s possible to switch out that center bulb for an hid kit or something.
l.abrego is offline   Reply With Quote
Old 10-18-2017, 08:29 AM   #2
Gossamer
Drives: 2012 Camaro Convertible
Are you sure they're halogen and not what they called the xenon headlight?
Take off one of the covers to identify what kind of bulbs are in there.
But from the look of the connectors, you have the HID style.
If they're the xenon in your pictures you're missing the ballasts
Gossamer is offline   Reply With Quote
Old 10-18-2017, 08:35 AM   #3
Reaper85
Drives: 2013 2SS/RS
I've never seen a halogen wth the projector lens.
Looks like the hid's. Like Gossamer said, you'll need the ballasts.
Reaper85 is offline   Reply With Quote
Old 10-18-2017, 08:46 AM   #4
l.abrego
l.abrego's Avatar
Well im not sure I’ll attach a picture of the bulb.
Old 10-18-2017, 08:52 AM   #5
l.abrego
l.abrego's Avatar
Here they are
Old 10-18-2017, 08:54 AM   #6
l.abrego
l.abrego's Avatar
Old 10-18-2017, 08:59 AM   #7
l.abrego
l.abrego's Avatar
The ballasts are this box though right? Because it also has this gray box to plus with the lights I don’t have any pictures of it or them with me to take right now.
Old 10-18-2017, 09:10 AM   #8
xc_SS/RS
Drives: 2010 Camaro SS/RS
which wires were connected to the bulb? Two of the four wires that feed into the outer projector look like connectors for a PNP HID kit
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 10-18-2017, 09:20 AM   #9
Gossamer
55W are normally a high beam setup. What's behind door #2 with the 3 connectors??
35W is 'normal' for a low beam setup.
However manufacturers vary what they run. I've got an RS, so I can't help other than what I'm seeing.
Old 10-18-2017, 09:22 AM   #10
l.abrego
l.abrego's Avatar
The ones on the right where connected to that box and then from there to the cars connecter I had someone do it for me because im not very familiar with this and he couldn’t get the low beams and high beams to work only the U shaped rins would work when given power to them.
Old 10-18-2017, 09:23 AM   #11
l.abrego
l.abrego's Avatar
Yea I noticed that I thought it was supposed to be like 35W and its the same thing
Old 10-18-2017, 09:25 AM   #12
Gossamer
so behind both access doors you have halogen bulbs at 55w?
Old 10-18-2017, 10:07 AM   #13
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Those are H7 bulbs I believe. Try replacing them. When I purchased new headlights from the same company for one of my previous trucks, the bulbs went out rather quickly. I replaced them with new white style ones and all was good
They are just regular halogen bulbs though
Coz3z3 is offline   Reply With Quote
Old 10-18-2017, 11:27 AM   #14
Gossamer
those are H7 bulbs, however there's 2 bulbs per headlight. I'm wanting to see what's behind the 'door' with the 3 connectors.
