Old 12-23-2017, 09:36 AM   #1
MG_PL
MG_PL's Avatar
Drives: 2013 SS EU-spec.
Brake upgrade... SS->ZL1
Hello!
Do I have to change brake lines when upgrading front brakes from SS to ZL1?
Or can I use SS brake lines with ZL1 calipers?
Thanks for help!
MG_PL is offline   Reply With Quote
Old 12-23-2017, 09:55 AM   #2
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Short answer is yes.
There is a long thread on doing the 6 piston swap that includes part numbers.
http://www.camaro5.com/forums/showthread.php?t=418667
Good luck
Craig
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 12-23-2017, 10:16 AM   #3
MG_PL
MG_PL's Avatar
Thanks!
ZL1 and CTS-V front brake lines and calipers are the same, right?
Old 12-23-2017, 10:34 AM   #4
SS Performance
ZL1, CTSV, and Z06 Brembo 6 pistons are the same. ZL1 and CTSV front rotors are the same.
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
2008 HHR SS
Old 12-23-2017, 10:46 AM   #5
MG_PL
MG_PL's Avatar
And brake lines? ZL1 and CTS-V are the same? But different than SS?
Old 12-23-2017, 02:21 PM   #6
SS Performance
Don't know about the CTSV but the ZL1 and SS are different. Most people go with the Goodridge stainless steel flex lines 12227
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
2008 HHR SS
Old 12-23-2017, 02:47 PM   #7
MG_PL
MG_PL's Avatar
Thanks for help!
If ZL1 and CTS-V calipers are the same then brake lines should also fit...
