01-26-2016, 09:23 PM | #1 |
My son broke this!?!?!
So my son broke the cover off the pass seat belt I posted before but I have a question does anyone know the size torque screw driver needed to replace it ?
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
01-26-2016, 09:35 PM | #2 |
Drives: '23 LT1 A10 Join Date: Oct 2015
I would just guess, a t30-t35. I wish I had a son to break things though :(
01-26-2016, 09:57 PM | #3 |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
It's a T-50
Sent from my campfire using smoke signals |
01-26-2016, 10:06 PM | #4 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
This. T50 and it will fight you the WHOLE WAY OUT if past GM seat belt bolts are any indication to this one. They (past bolts I've removed, anyway) have a thread locker goo on the entire shaft of the annoyingly long bolt.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
01-26-2016, 11:05 PM | #5 |
Thanks guys !!
01-27-2016, 09:12 AM | #6 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
Make absolutely sure you get a good quality torx bit. That bolt is going to be a mother to get out and it will be tight as hell. The put a ton of thread locker on it from the factory and the don't want it to come out. I have destroyed more than a few cheap torx bits trying to get those loose. You definitely don't want the bit to break or slip off and risk damaging any interior parts.
USMC 1980-1990
My other toys are Harleys |
01-27-2016, 09:14 AM | #7 | |
01-27-2016, 09:32 AM | #8 |
USMC 1980-1990
I would be looking at Craftsman, Matco or Snap on, those I have had good luck with. Stay away from harbor freight or anything sold at an auto parts store. Those are normally just cheap cast and won't hold up to anything with high torque requirements. Just my .02
USMC 1980-1990
01-27-2016, 09:46 AM | #9 |
Drives: 2011 L99 SS Join Date: Oct 2014
If you can fit a cheater bar in there for more leverage while someone holds the bit, it should make it easier.
01-27-2016, 11:21 AM | #10 |
If you have an air compressor, get a Torx impact bit in 3/4 drive and an impact gun to go with it.
01-27-2016, 11:40 AM | #11 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
Use a torch comes right off.
01-27-2016, 02:19 PM | #12 |
Account SNAFU
Meh I used a harbor freight special T-50 and an air ratchet and it backed right out
01-27-2016, 02:59 PM | #13 |
USMC 1980-1990
You've been a lot luckier than me, I always end up twisting the ends or breaking at least one bit every time. Even with an 1/2" 18" long breaker bar and being real careful not to damage anything around it.
USMC 1980-1990
01-27-2016, 03:58 PM | #14 | |
Account SNAFU
