01-08-2014, 05:47 PM | #1 |
REMOVING TRUNK LOGO 2010 SS CAMARO WITH HOLES
I am having issues removing the trunk logo on a 2010 camaro. It has two holes connecting the emblem. I've already looked on the thread but can't find how to remove it with holes. I used the same method as without holes but it still wouldn't budge. What tools should I use. I dont want to break the logo or damage paint.
01-08-2014, 05:47 PM | #2 |
Can someone PLEASE HELP!!!!
01-08-2014, 07:08 PM | #3 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
fishing line? never wanted to move one but that is where I would start
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
01-08-2014, 07:23 PM | #4 |
knows 2 facts about ducks
Might have more luck in the cosmetic lighting mods subforum
But Goo Gone and fishing line is all you need. |
01-08-2014, 07:32 PM | #5 |
Drives: 2010 2SS/RS M6 Join Date: Dec 2013
Fishing line an goo gone adhesive remover. That's what I used and mine came off easy. I did my whole car that way in like 20 mins ..
01-08-2014, 08:00 PM | #6 |
Reaper Crew
Drives: Blown 2010 Camaro SS Join Date: Aug 2012
Heat gun and a nylon putty knife, mine came off very easily using this method
2010 Camaro SS SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP Pedders XA Coilovers |
01-08-2014, 08:27 PM | #8 |
I used fishing line to cut through the adhesive on both sides up to the pins that go into the holes, then used a plastic/nylon pry tool and a hair dryer to heat the bow tie, to pry it off. Lay down several layers of masking tape around the bowtie and try to work some under the edges too. This is so when your prying the bow tie off, the other side is not digging into the paint.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
01-08-2014, 09:54 PM | #9 |
Drives: 2013 Black 2 LT vert Join Date: Jul 2013
is there a black vynal cover that can go over the rear bowtie? i dont like the yellow color and is plasti dip more messy to work with?
01-09-2014, 01:53 AM | #10 |
01-09-2014, 02:20 AM | #11 |
Cut behind the bow tie with fishing line after you have went over it and it's no longer able to stick pull it off with your fingers it will come off.
01-11-2014, 02:07 PM | #12 |
Drives: 2014 Camaro SS/RS BRM Join Date: Dec 2013
so the rear bowtie is just glued on? No holes to deal with?
I have a 2014 SS if that makes a difference. |
01-12-2014, 10:50 PM | #13 |
Drives: 2011 Camaro 2SS/RS Vert Join Date: Jul 2011
The 2010 bow tie was held on with adhesive and pegs on the back, to my understanding 2011-2014 are just adhesive. (When you take it off be sure to mark where it was if you plan to put it back on.)
01-13-2014, 07:16 AM | #14 | |
The pegs were just for alignment - they didn't actually help hold the bowtie on. |
