06-26-2014, 04:55 AM | #1 |
Jersey
Drives: 2010 cammed n supercharged SS Join Date: Jun 2012
NJ inspection question
Sorry if this was asked already but I just got back to Jersey today from cali been gone like 7 years due to military but I need my car inspected idk if I will pass I have LTs, cam, no cats, supercharger, and exhaust. Does anyone no if I will pass.
Thanks so much Kevin
-PFADT SUSPENSION
-1.25" Drop Springs all around, -Front and Rear Sway Bars, -Sway Bar End Links, -Rear Tie Rods, -Rear Trailing, Arms, -Subframe Bushings, -Polyurethane Diff Bushings, -RUCA Bushing w/Bracket, -GForce 1400 HP Outlaw Axles-Manley Hardened Pushrods, -McLeod RXT Twin Disc Clutch kit with Aluminum Flywheel -MGW Short Throw Shifter,-Ati Balancer LS3, -MSD Boost-A-Pump w/vacuum line,-Fast 65# injectors LS7, -MTI Racing Stage 3 LS3 Camshaft-231/243, -valve springs, retainers, valve seals, cam sprocket, -Stainless Works Long tube headers with CAT delete, -F1-A Procharger |
06-26-2014, 07:13 AM | #2 |
Drives: 2010 Camaro 2SS/RS M6 BLK/BLK, Join Date: Nov 2009
They check for CATS!
Artful Dodger 2010 Camaro 2SS/RS M6 BLK - 2015 Maserati Ghibli Q4 BLK (dd) - 2004 MB C240 BLK (wife's) - 1996 BMW 328i BLK
06-26-2014, 07:13 AM | #3 |
06-26-2014, 07:14 AM | #4 |
06-26-2014, 07:15 AM | #5 |
NJ has become a plug it in state, if not codes you pass, but they still check for CATS!
06-26-2014, 07:15 AM | #6 |
NJ has become a plug it in state, if no codes you pass, but they still check for CATS!
06-26-2014, 09:00 AM | #7 |
Jersey
So what about a private inspector do you no anything about them?
-PFADT SUSPENSION
06-26-2014, 09:38 AM | #8 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
I'll post this once...lol Artful is correct, they will pass you for anything. However, when they drive over the rollers, they check for the presence of cats. If you have something on there that makes it look like cats, they won't look twice. As far as the ECU check, as long as there are lights on, you'll be fine.
If you choose to use a private inspector, chances are that they'll more likely pass you. It all depends on their morals and how they feel that day. If you weld on some cans to make it look like you have cats, then go through the free one first. |
06-26-2014, 12:49 PM | #9 | |
ZLT!!! COTW (8/5/13)
Drives: 2011 IOM 1LT RS M6 Join Date: Mar 2012
06-26-2014, 01:36 PM | #10 |
Drives: 2013 Silver Ice Metallic Join Date: Aug 2013
Not to thread jack but I'm a jersey boy too. What are CATS?
06-26-2014, 06:25 PM | #11 |
Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
