09-06-2010, 08:33 AM | #1 |
Drives: Victory Red 2SS Join Date: Feb 2010
Drone...
I put an aftermarket cat-back system on this weekend and it has a bad drone (the instrument panel is rattling at around 2k rpm). I have a L99 still with the AFM, but it has the same drone if I use the paddle shifters (so I really don't think its the AFM kicking in, I can hear that too but its almost drowning in the drone). Would a tune help this or will the drone still be there?
I have been thinking about solutions. and came up with three potential: 1. put a resonated x pipe, 2. put two resonators after the existing x 3. put a Helmholz bend on like has been described on these forums 4. put fatmat in the trunk. What do you think would be the best solution? And please no comments like Man up or live with it... This is a horrible resonance frequency in the cabin not V8 as it should sound. |
09-06-2010, 09:01 AM | #2 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Which system did you get?
A resonated Xpipe might help some, but it probably won't eliminate it. Helmoltz tube might fix it. Dynamat won't fix it, just muffle it some.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
09-06-2010, 09:29 AM | #3 |
I added a Magnaflow Street Catback to by L99 a few weeks ago. I've never noticed the "drone", just that damn AFM noise that's been there since we bought the car. Mine goes away when I drive it in Manual mode though which is why I'm going to turn off AFM! Are you sure it's not AFM noise? On a couple of occasions I've had my AFM kick in for no reason while using the paddles, though it goes away once I shift it up or down.
I went with the Street because I feared the drone! I think I made a good choice. Steve |
09-06-2010, 09:30 AM | #4 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
The only thing that really gets rid of the drone are tuning pipe. They are deadended pipes that reverberate the sound back into the exhaust to cancel the drone. Depending on your current system there is probably an option out there. The Solo exhaust guys could help you out with a recommendation. I know a couple people who have had good luck with this even when the original exhaust wasn't one of theirs.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
09-06-2010, 09:56 AM | #5 | |
Drives: 2017 ZL1 Join Date: Dec 2009
Or just buy the Corsa catback no drone and everyone who has it says the same.
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
09-06-2010, 11:37 AM | #6 |
So I am looking around for resonators. But oddly enough they don't specify what frequencies they target, you would think that would be of interest.
As for two straight resonators or resonated X, what is the difference in sound cancelling? I am just assuming that these resonators in someway are helmholtz style cavities as well, just not a tube, or am I wrong? |
09-06-2010, 04:01 PM | #7 |
28" Helmholtz chambers on each pipe will fix you up. And that's the truth.
09-06-2010, 04:22 PM | #8 | |
So It'll Go Down Easy
Drives: Camaro SS/RS Join Date: Aug 2010
09-06-2010, 04:49 PM | #9 |
Drives: 2015 c7 Join Date: Nov 2009
corsa is really the man... they give one of the loudest cat backs with no drone
09-06-2010, 05:53 PM | #10 |
Motor Head
Drives: CTS-V Join Date: Feb 2009
I tried the muffled X-pipe - made the drone worse. I like the J-pipe much better. But, it does make the system a little quieter.
History Camaro's: 83, 93, 95, 98, & 10.
09-06-2010, 06:06 PM | #11 |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
Here we go again......DRONE.......
Corsa is the ONLY one that won't make your head pop...... I wasted time and money till I got the Corsa system.
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
09-06-2010, 07:44 PM | #12 |
Pro Hide n Seek Player
Drives: 2010 SS LS3/LSA 620whp/630tq Join Date: May 2009
My Borla-S type has a little drone, but its not bad at all.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC |
09-06-2010, 08:11 PM | #13 | |
Drives: 2015 CAMARO SS LS3 Join Date: Jun 2010
09-06-2010, 10:54 PM | #14 |
But I don't really feel like spending $1200+ for another system. It will be fixing this or going back to stock...
I will give a J-tube a try next weekend or the weekend after, busy at work right now... Does it matter if it goes before or after the mufflers? |
Similar Threads | ||||
Lets talk about drone (i.e. what is, and what is not) | MarylandSpeed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 80 | 07-16-2011 07:21 AM |
Lesson Learned:Muffler Delete Drone | JMROD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 154 | 06-02-2011 04:43 PM |
Solved my drone problem! | GrinderSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 07-31-2010 12:11 AM |
exhaust drone damper weights ? | skar | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 07-12-2010 06:33 PM |
Bad Drone w/ JBA Exhaust | GrinderSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 06-22-2010 12:58 AM |
