Old 01-19-2014, 08:31 PM   #1
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
GEARS!! Am thinking about gears...
I am thinking if I get gears, that will finish off the car...have had a cam in for 2 months now(haven't been able to thrash it because of the weather). I am thinking about the 3.91's. I never use 6th gear now, so maybe I might be able to use it. probably would install myself...should be easier than the cam was...
any opinions about ratios??
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
Old 01-19-2014, 09:17 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
3.91's are quite popular since they're OEM (1LE) and cheap. If you're a M6, you're good to go. If you're a A6, the 3.70's would be ideal but 3.91's would still work quite well.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-19-2014, 09:19 PM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Im about to install 4.33s should be a blast on the street. I was considering the 3.91s before the 4.33s
ttshovel is offline   Reply With Quote
Old 01-19-2014, 09:25 PM   #4
axis
Search Ninja
axis's Avatar
I see a LOT of second gear starts in your future, lol.
Halltech CF 102 fed
Old 01-19-2014, 10:55 PM   #5
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
The 3.91s are pretty popular, but in a M6 I would suggest going with a 4.10 if you will stay NA. Makes for a much nicer ratio on the street and the track.
Lethal Racing is offline   Reply With Quote
Old 01-19-2014, 11:23 PM   #6
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Love my 4.10's...looking back, best mod I've done
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 01-20-2014, 04:16 AM   #7
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Hey 40MPH and I am in 6th with my 3.91's
Scott@Bjorn3D is offline   Reply With Quote
Old 01-20-2014, 07:03 AM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
3.91 and 4.11 are both really great street/strip ratios the M6 cars. By upgrading to 3.91s you will realize an equivalent torque gain of approximately 13% or 54.6 lb.-ft. of torque and cruise at 1800 RPM at 70 MPH in 6th gear. By upgrading to 4.11s you will realize an equivalent torque gain of approximately 20% or 84 lb.-ft. of torque and cruise at 1915 RPM at 70 MPH in 6th gear.
Unless you have experience installing gears, particularly in IRS cars, I do not recommend trying it yourself. It is one of those things that requires a bit of artistry in addition to the technical know how. Even if you are capable of completing the install there is a big of difference between a good install and a bad one. Just be sure to do some research before you finalize that decision.
Old 01-20-2014, 07:22 AM   #9
Mwalterhouse
Mwalterhouse's Avatar
Drives: 2010 Camaro SS/RS LS3
I am with you , 3.91 gears in the spring.
Mwalterhouse is offline   Reply With Quote
Old 01-20-2014, 07:34 AM   #10
ssmike
BL1ZZRD
ssmike's Avatar
Just the opposite here. I have the 3.91's but am thinking of doing a cam! I think this combo would be perfect together!
Old 01-20-2014, 10:30 AM   #11
mdub76
mdub76's Avatar
Drives: 2010 2ss/RS IOM GFX M6
Adding gears makes driving a cammed car so much easier
mdub76 is offline   Reply With Quote
Old 01-20-2014, 10:48 AM   #12
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
L99 here with recent 3.91s and it's amazing. you won't regret doing this!
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
Old 01-20-2014, 01:37 PM   #13
black79ta
black79ta's Avatar
Interesting correlation between torque and gear ratio. Was wondering how to compare...If I do it myself I would do Plenty of research. Just started thinking about it now
Old 01-20-2014, 01:41 PM   #14
black79ta
black79ta's Avatar
M6 btw
