03-09-2013, 06:40 AM | #1 |
Drives: 2013 ZL1, Panoz GTWC, 2013 Durango Join Date: Feb 2013
Why does the Roto Fab not require a tune while all other intakes do?
What is the difference in the Roto Fab intake that does not require a tune while every other intake requires this? They all have high flow filters and larger diameter plumbing so what makes the difference? I recall one tuner on this forum suggesting that in their opinion the Roto Fab does need a tune. Any opinions on this?
03-09-2013, 08:03 AM | #2 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Bryan 2018 ZL1 M6
03-09-2013, 08:16 AM | #3 |
COMPULSIVE CAMARO OWNER
Drives: 18 ZLE,14 2ssrs,96,73 RS LT,69&67 Join Date: Nov 2009
Seriously, why the scepticism? How many of us have to post that it.works before you believe it? Todate i have 4000 miles on my 2013 zl1 (so there is no.question which car i am talking about) with no checkengine lights, this is since install. Probably 500 since big gulp install. As easy as it is to flame a company about a.product not.delivering what it says,.the abscence of that alone should convince you. I am not a paid spokes person. I have 750$ into the pair. Best money i have spent. Can we stop beatingtrigger already. If you want to hear it in person fly into denver and come take a ride inmy car. It will also bein sturgis tearing up the autocross. Sturgiscamarorallycom
03-09-2013, 08:52 AM | #4 | |
Drives: '12 Camaro ZL1, '16 Silverado Z71 Join Date: Mar 2012
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust |
03-09-2013, 08:54 AM | #5 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
ADM's street intake does not require a tune either.
URR2SLO - If you're not going fast enough, get out the way......
03-09-2013, 09:29 AM | #6 | |
This. And I am also curious. I am planning a modest build and like the feed back on the Roto-Fab cai but as I intend to tune my Z I would love more data on gains with a tune for the Roto-Fab as others have already published their data.
Laus Deo
03-09-2013, 09:36 AM | #7 | |
Drives: . Join Date: Nov 2012
It's posts like this that piss me off. The guy asked an honest question and he only has 7 posts here. Way to make him feel welcome. |
03-09-2013, 09:49 AM | #8 | |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
OP - It comes down to the design and diameter of the intake tract that houses the MAF sensor. As sophisticated as the ECM is; it can only compensate so much without a recalibration due to increased airflow. The slot style MAF sensors used in this car are very sensitive to air volume and speed changes. That sensitivity is increased because GM no longer uses a screen (actually air flow straightener) in front of the sensor like in the older heated element design. |
03-09-2013, 10:21 AM | #9 | |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
The ADM for the ZL1 does in fact require a tune.
It's all about the location of the MAF
03-09-2013, 10:21 AM | #10 |
if i would buy a new zl1 ,rotofab intake would be my first mod . without hesitating.
03-09-2013, 10:38 AM | #11 | |
Bryan 2018 ZL1 M6
03-09-2013, 11:10 AM | #12 |
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
I have a Rotofab on my car with no tune and have had it on the Dyno twice since installation - last result was 526rwhp
AF ratio is perfectly safe and it most definitely does not REQUIRE a tune. The last guy who had it on a Dyno was skeptical when I said it had no tune, but was very impressed with the results once some readings were taken. It's all about the design of the MAF housing and they put a lot of time into the R&D on that to make it a no tune required intake. That doesn't mean you won't get better results by tuning, it just means you get very good safe results without having to tune if you don't want to.
03-09-2013, 11:15 AM | #13 | |
03-09-2013, 11:17 AM | #14 | |
I welded a bung as soon as I bought my car. I have used a LM2 wide band. I will not do any tuning for a long time, due to the warranty. Yes JTE has done a wide band test and all other test on the ZL1. They are all the same stock if you have about the same set up and mileage. If the fuel trims where off by by a large amount it will throw a code. You are right, it will not be perfect. Last edited by Skylane765; 03-09-2013 at 11:33 AM. |
