01-17-2016, 12:52 PM | #1 |
Drives: 2013 Black-on-Black 2SS/RS Join Date: Jan 2014
Just moved back to CA, quick smog opinion needed
So I just moved back from Pennsylvania, where emissions were much more relaxed than they are here. Tomorrow I'll be replacing all my stock parts, intake, TB, LT headers and hi-flo cats. The only thing not stock on the car will be the comp cam. Of course the question is, after replacing the external parts, should my car pass CA smog with the cam? Without retuning? Any insight on this would be greatly appreciated. I'm attempting to sell my car, and need to attempt to smog it this week. Thank you
Performance Mods: CAI intake, BBK 95mm TB, 1-7/8 SP LT Headers, Comp Cam. 466rwhp
01-17-2016, 05:22 PM | #2 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
How big is the cam?
01-17-2016, 06:16 PM | #3 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
My understanding is that the new smog procedures are to plug into your obd port and check for codes. If there are no codes and you pass the visual (which you should since your going back to stock parts) you should be fine. No more sniffer test
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
01-18-2016, 01:30 PM | #4 | |
Drives: 2011 1LT Join Date: Mar 2012
I recently had to smog a 2002 Corolla. The f'n OBD codes were cleared after various repairs (new battery, new catalytic converter), but the car must be driven a certain distance, and/ or certain drive conditions must be met before the smog reader will accept the codes as COMPLETELY cleared. I ended up driving around pointlessly for over 600 miles --- after repair, and check engine lights were off--- just to get the codes to be accepted. I have a hard time believing that my 600 miles of pointless driving around will result in a net reduction of emissions into the atmosphere. But, hey, California. |
01-18-2016, 01:47 PM | #5 | |
Drives: 2010 camaro 1ss Join Date: Dec 2013
01-28-2016, 08:18 PM | #6 |
Drives: 2015 SS Sedan M6 Join Date: Dec 2009
01-28-2016, 09:40 PM | #7 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
OP...give us an update!!
2015 Z/28 #642 Black Bad Ass
01-29-2016, 09:15 AM | #8 | |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
Welcome to Cali - what area? |
01-30-2016, 01:38 AM | #9 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Just replace the exhaust. TB shouldn't be an issue because the stock one isn't stamped. Just make sure you have the factory air box installed.
02-01-2016, 01:41 PM | #10 |
dont need the factory airbox if you have a CARB approved CAI - Volant has a certified and approved system...
Thread Tools | |
