Old 11-17-2016, 11:27 AM   #1
pumpman
pumpman's Avatar
Drives: 2010 SS and 2005 Acura TL
Need a little help..... amp, subwoofer and 4 speakers
Camaro SS with BA system..I plan on keeping the stock head unit.
What will I need in the way of kits to install these items?
All items are MMats Pro Audio; 5.1 channel amp, 10" sub, 6x9
rear deck speakers, and 6.5" front door speakers.
Thank you guys
pumpman is offline   Reply With Quote
Old 11-17-2016, 01:10 PM   #2
cabbe
Drives: 2014 2ss 1le
Subwoofer box and amp mount plate as well as speaker adapter rings. You can get it all from s u b t h u m p.
cabbe is offline   Reply With Quote
Old 11-17-2016, 01:12 PM   #3
cabbe
Oh, and a fark as well.
Old 11-18-2016, 09:37 AM   #4
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
I did the same and used the FARK from said source as well as the stealth box and amp board from the same site. I just have not replaced the rear speakers, heard it is the most painful experience. I just dont really use them. I used different speaker adapters though, I think from metra or something. They worked a lot better than the ones I originally received from the other place.
cybercoaster is offline   Reply With Quote
Old 11-18-2016, 10:10 AM   #5
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
I just got done doing the exact same thing as you. I used the plastic scoshe adapters in the doors. Nothing to get wet or swell. I will not change the ones in the rear deck either. No need to use them.
Rainbow1616 is offline   Reply With Quote
Old 11-20-2016, 10:41 AM   #6
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
My balls....
Camaro DIY
Speaker Install
BA System Upgrade Advice
Non-BA Amp install, Head unit questions
DIY: Non-BA Full Sound System Install w/ Stock Radio
Non-BA Speaker Upgrade
DIY-Adding a Sub/Amp to a BA system via RCA splicing
I might be onto something...
...what do you think JimE? I'm thinking I'll create a master clipboard and just update it occasionally to reply with.
Snoman is offline   Reply With Quote
Old 11-20-2016, 07:38 PM   #7
tuantrang
Drives: 2013 Camaro
What kind of stereo you got? Are you planning to use stock radio or aftermarket?
If you don't know what you doing i suggest taking it to the professional.
tuantrang is offline   Reply With Quote
Old 11-22-2016, 03:04 PM   #8
Imdyinhere
Keeper of the Gold Acorn
Imdyinhere's Avatar
Drives: 2011 2SS/RS
OP said he was keeping stock HU.
2011 RJT 2SS/RS - Kooks 1-7/8 Long Tubes, High Flow Cats, Corsa Cat Back Exhaust, MTI Short Throw Shifter, Vmax Ported Throttle Body, Fasster Billet Fuel Rails & Custom Braided Vapor and Fuel Lines, CAI Cold Air Intake, RX Catch Can, Nitto Invos, Hawk HPS, BMR Trailing Arms, 2x Zapco ST4x-SQ amps, ST850x-II Sub amp, Morel Tempo 6 componenets, Morel Maximo 6x9, Morel 124 Primo Sub, Zapco DSP8Z Processor... More to Come.
Imdyinhere is offline   Reply With Quote
Old 11-22-2016, 07:05 PM   #9
tuantrang
Drives: 2013 Camaro
With stock radio you will need PAC aa-gm44 http://www.pac-audio.com/productDeta...&CategoryID=28.
Old 11-23-2016, 06:54 PM   #10
pumpman
pumpman's Avatar
Thanks Guys....I ended up taking to a shop and let them do it.
I do have a question, this seems very bizarre. My FM reception seems to have been affected.....station I used to hear is barely picked up and local stations are now a little static......how could the antenna been affected or antenna cable? can't take the car back for them to look at until Friday/Saturday.
