03-12-2014, 09:55 PM | #1 |
Drives: 2011 Red 2SSRS A6 Join Date: Jan 2011
Rupes Polisher Pads
I'm looking at getting a Rupes 15ES pretty soon, to add to the arsenal. What pads would you recommend getting to fit it? I want a 5" to 5.5" pad.
MPD1 Z Force hood, 1LE splitter, ZL1 rockers and diffuser, Heritage grille, Sparks Restorations emblems, Magnuson Supercharger, ID850 Injectors, Alky Methanol Kit, Livernois Fuel Pump Roto-Fab CAI, SW long tube headers, CNC ported throttle body, High flow cats, Lethal Racing Prowler Cam, LS3 conversion, Yank 3400 Stall, Corsa 3" cat back exhaust, RX Catch Can, BMR Suspension, BC Coilovers, Slotted and Cross-drilled rotors, Custom Interior.
03-12-2014, 10:08 PM | #2 |
I like teeth.
Drives: #198 Join Date: Oct 2009
Lake Country Flat Pads. Cheap, effective, reliable, last forever if taken care of.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
03-13-2014, 07:40 AM | #3 | |
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
They are perfectly weighted to the machine. As you increase stroke and move the weight away from the pivot, differences in balance become more critical. The Rupes pads are perfectly weighted for the counter balance of that machine, and with a 15-mm stroke, you will appreciate the difference. Also, Rupes increased the velcro adhesion of the pads to their backing plate, which otherwise could become a weak spot when subjected to the pad stresses that a 15-mm throw could induce. |
