04-19-2015, 08:58 PM | #1 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
V6 getting close to the 11's...
Ran a new best tonight, 12.28 @ 117.44mph.
Thunder Valley Raceway, low 60's, DA was 1800-2000 Would really like to get to the 11's. I think a lightweight drag wheel setup might get me there. I'm car #497 |
04-19-2015, 10:16 PM | #2 |
"Cam Only"
Get that 60 down and you're there based on your mph
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
04-22-2015, 04:02 PM | #3 |
Drives: Synergy Green SS Camaro 6 speed Join Date: Sep 2014
Yeah your 60 foot is killing you.
Synergy Green Camaro SS LS3 TH400, Stock Ported heads, Night Fury cam 4600 Circle D stall. 3.91 gears and rotofab intake, obx headers,
04-22-2015, 07:31 PM | #4 |
Yeah I know, my 60ft is embarrassing. My tune is limiting my launch right now, it's a canned type tune and it won't let me rev the motor when I'm on the brake. If I have my foot on the brake at all it won't even let me rev over 1K, even after holding the tc button down 8 secs and all nannies off. I have to stage, pull my e-brake, and take my foot off the brake, then I can only rev a little because the e-brake only holds so much. I need to get that sorted out, it's fine for the street(except no brake stand burnouts) but not good for the strip. I'll have to do an SS rear diff/axles, torque convertor, and drag wheel/tire setup along with it though or it would be pointless. I'm on factory 20" wheels with Gmax all seasons and the small v6 auto open rear diff. I definitely have a list just takes $$$... and I'm just an auto mechanic AND I have a teenage daughter lol.
04-22-2015, 09:39 PM | #5 |
Drives: 2011 Camaro SS L99 Join Date: Jan 2012
A pair of MT Drag Radials should do it for you. Probably 3 to 4 tenths off the 60'.
06-01-2015, 07:01 PM | #6 |
Drives: 2014 2ss/rs Join Date: May 2012
a Line Lock will handle the front brakes for ya....
install a 'go' button..... |
06-02-2015, 10:19 AM | #7 |
Getting closer, 12.180 @ 119.4 mph.
06-03-2015, 02:59 AM | #8 |
Drives: 2013 Camaro SS Coupe L99 Join Date: Feb 2013
You just keep your a$$ in the 12's your making me look bad J/K great job op.
06-03-2015, 09:57 AM | #9 |
Drives: 2015 LFX Auto Join Date: Apr 2015
Your so close....get that 60' down and your there!!
06-03-2015, 11:54 AM | #10 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
DRs on there?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
06-03-2015, 01:09 PM | #11 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
Glad to see someone else getting close. How about if you put a line-lock on the rear brakes to hold you on the line under some throttle. My Weld RTS 17s on all 4 corners netted me .11 ET and 3mph just switching rims and tires. But you also talking $$$$$$. Who's TT setup are you running and what's your boost PSI. Anything I can do remotely to help just ask or PM me and I'll give you my mobile # if we can talk to help you get there. I'm going for that 11:xx ET myself. See you on the 11 side. Good Luck.
06-03-2015, 03:47 PM | #12 |
06-03-2015, 03:58 PM | #13 | |
And thanks I'll PM you sometime I'm sure, I'm always looking for peoples opinions. |
06-03-2015, 04:08 PM | #14 |
