Old 07-17-2015, 12:01 PM   #1
1troyd23
Drives: ZL1
Catch Can ?
Sorry guys, another question for all you guys. As stated before, I have a brand new 2015 ZL1 , I ordered my Roto-Fab CAI and it should be here today, but I also have read a lot about catch cans...So the only engine mod I will be doing is the CAI and the car will basically be a weekend driver not a DD, do I really need a catch can ? And if so , does this void factory warranty ?
1troyd23 is offline   Reply With Quote
Old 07-17-2015, 12:15 PM   #2
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
It does not void any warranty... You don't "NEED" it but it keeps oil out of your throttle body and basically just keeps things cleaner so you don't have to. Your engine will not fail due to not having a catch can.
It is basically preventative maintenance that you would otherwise have to do in order to keep things running smoothly.
jayno20 is offline   Reply With Quote
Old 07-17-2015, 12:19 PM   #3
1troyd23
Drives: ZL1
great thanks !! How much $$ does a good quality one cost ?
Old 07-17-2015, 12:42 PM   #4
gto
Drives: gto
you should check with chase from apex motor sport.
He has many to pick from.
It really does it job, from keeping your motor cleaner in the long run.
gto is offline   Reply With Quote
Old 07-17-2015, 12:55 PM   #5
1troyd23
Drives: ZL1
any contact info for this guy chase ?
Old 07-17-2015, 01:10 PM   #6
jayno20
Go fast, please.
jayno20's Avatar
http://www.apex-speed.com/apex-motor...n-apx9001.html
Old 07-17-2015, 01:16 PM   #7
1troyd23
Drives: ZL1
thanks !!
Old 07-17-2015, 02:02 PM   #8
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado
http://youtu.be/HoONJfRbsSo
ZL W0N is offline   Reply With Quote
Old 07-17-2015, 07:06 PM   #9
1troyd23
Drives: ZL1
ok, guys..not to beat a dead horse, but I was thinking about this on my way home from work. so what does changing the stock air intake to any other after market cai have to do with a catch can ? I mean the stock set up didn't come with one right ? in other words, if you were not going to change out you stock intake to , would you still install a catch can ?
Old 07-17-2015, 07:24 PM   #10
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
Two independent systems, just both happen to be common first modifications. The catch can is for the bottom side of your pistons and valve train pressure and ventilation. From the factory the intake system sucks the oil vapors from the crankcase and runs it through the engine to keep everything "contained".
The catch can allows the oil vapors to settle in the can instead of feeding it back into the intake tract.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 07-17-2015, 07:47 PM   #11
1troyd23
Drives: ZL1
thanks for that info Redlineviper, but again, if you leaving your stock intake, would you still need or want to install a catch can ?
Old 07-17-2015, 07:53 PM   #12
Redlineviper
Drives: 2013 ZL1
Yes, same benefit with the stock intake vs aftermarket.
2013 A6 ZL1
Old 07-17-2015, 07:57 PM   #13
1troyd23
Drives: ZL1
thank you so much, waiting for UPS to deliver my new Roto-Fab CAI as we speak !!!
