05-15-2013, 09:32 PM | #1 |
Drives: 69 camaro prostreet, 2010 abm 6m Join Date: Jan 2013
tools needed to install lowering springs
Going to install 1" lowering springs tomorrow myself and I have a spring compressor. Just wondering if anybody has done it and would know of special tools are required i.e. large MM sockets or anything else that I might not have. I have a 2010 and any help would be great. Thanks
05-15-2013, 09:41 PM | #2 |
knows 2 facts about ducks
Check out the Big DIY Index sticky in the DIY subforum. Very good detailed instructions on how to install lowering springs in there.
05-15-2013, 10:09 PM | #3 | |
ROAD COURSE JUNKIE
05-16-2013, 09:52 AM | #4 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
I don't know the sizes off the top of my head but you will need some deep MM sockets, a 1/2 inch breaker bar, a 1/2 inch ratchet, a electric impact wrench will help for some of the bolts for some it isn't strong enough, the spring compressor of course and if i am not mistaken you will need a Torq head (they almost look like an Alan wrench). Oh an I almost forgot a Torq Wrench to put the lug nuts back on to the correct strength.
10-15-2015, 08:22 AM | #5 |
Drives: 63' chevy impalaSS , 12'Cam89'Cam Join Date: Feb 2013
That video makes it look pretty easy .. how important is a torque wrench ?
10-15-2015, 12:34 PM | #6 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
I wouldn't tighten most steering and suspension fasteners without one. I still do all of my own maintenance and modification work and most of the repair work.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
10-15-2015, 01:25 PM | #7 |
Drives: 2015 1SS / RS NPP Join Date: Apr 2015
Decent torque wrench isn't a horribly expensive tool either, and will last decades.
My thought process on tools is this, if I need one for something I want to do and can afford a decent one, buy it. It will come in handy to have it at some point in the future. It may not seem like it, but it will. I've honestly been surprised at how often that's been the case. Besides, a torque wrench is a pretty essential thing for all sorts of mechanical repairs / work. |
10-15-2015, 01:35 PM | #8 |
Master of Nothings
I didn't see them using a spring compressor in the video....
2010 Chevrolet Camaro 2LT/RS |
10-15-2015, 04:08 PM | #9 |
He did very specifically mention that a spring compressor would be used for most applications, and my money is on him having used compressors on the first Camaro springs he worked on. Never mind that if you're not a very heavy dude that you might not be able to compress even those springs by enough to get the nut caught on the re-assembly.
FWIW, I don't think shock/strut mfrs recommend the use of impact tools when installing the spring. IIRC, Konis or any others with the strut shaft drilled out for the adjustment mechanism specifically warn against using impact equipment. Norm
