06-16-2020, 06:48 PM | #1 |
Drives: 2017 Camaro 2SS Join Date: Jun 2020
2017 Camaro 2SS max speed 200 kmh.
When switching from US to metric units, the speedometer scale is still between 0 to 200, so it just sits at 200, when you go beyond 200 kmh.
Does anyone have the same problem? Is this by design? |
06-16-2020, 07:13 PM | #2 |
That's because the speedo is designed primarily for mph. Changing to km/h only changes the way the needle responds. It cannot change the 200 because that part is not digital. How often are you driving 124 mph (200km/h)?
06-16-2020, 07:27 PM | #3 |
Long hauler
As caSStro18 said, if it really bothers you can spend like hundred for a mph spec cluster and send it in to get programmed for $200 so like $300 for the cluster to be mph.
I don't think you can open the glass or gain entry to put a cover on it, it could be possible
06-16-2020, 10:50 PM | #4 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
There are two physical SS/ZL1 speedo designs with the 2016-18, one for the US (this is what you have) and another one for EU/AS, see below.
If this limitation is really a bother, you can obtain an EU/AS cluster and have experts like White Automotive & Media program it up for you to enable a swap.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
Tags |
metric, speed limit, speed limiter, speedometer |
