Old 10-01-2013, 12:52 AM   #1
BadAssZL1
BadAssZL1's Avatar
Drives: 2013 ZL1 Black on black
Wet driving!
I'm fixing to take a trip to hometown Jackson, Ms to show off new Z. IF it should rain, should I change to wet mode for better traction?? Thanks
Carol
BadAssZL1 is offline   Reply With Quote
Old 10-01-2013, 12:53 AM   #2
qniknam
Drives: 13 ZL1 | 13 SRT GC | 13 SRT CHARGER
I've put mine in wet mode once, it behaved pretty well.
qniknam is offline   Reply With Quote
Old 10-01-2013, 01:46 AM   #3
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
I have driven my car only twice since i purchased it 3 weeks ago,and its got 612rwhp,and it drove fine in the rain since it rain and rained freaking hard both days i just left it in touring ,and just didnt get crazy or go fast in it.
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 10-01-2013, 07:53 AM   #4
Drew P
Drew P's Avatar
Drives: Camaro ZL1
yes, use ptm1
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 10-01-2013, 08:23 AM   #5
Explit Player
IG @Brian_ _Self
Explit Player's Avatar
Drives: 2010 Camaro 2SS M6+17'Tesla Model S
Is the wet mode only on the ZL1s?
Explit Player is offline   Reply With Quote
Old 10-01-2013, 10:58 AM   #6
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
You can just leave it in touring where it is when you start the car. I usually go to PTM1 for the fun of it and compare the difference. Both work fine.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 10-01-2013, 11:26 AM   #7
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
I would definitely run in wet mode in the rain. And also be careful! There have been many ZL1 accidents and some in the rain. 580HP and rain do not go well together, add those tires and you are set up for an accident waiting to happen.
Respect the car!
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 10-01-2013, 11:48 AM   #8
jbotta
jbotta's Avatar
Drives: Camaro ZL1
Respect the car!
Well said sven59,, RESPECT THE CAR!
jbotta is offline   Reply With Quote
Old 10-01-2013, 12:01 PM   #9
snackbar64
snackbar64's Avatar
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR,
I imagine it would suck to live in Seattle with this car. This car terrifies me in the rain. Even driving slow and respectfully at 55 mph in a 70 mph zone on the highway the rear end still wants to fishtail. Also the manual tells you that wet mode is not intended for anything other than light rain. I was a bit puzzled by that.
snackbar64 is offline   Reply With Quote
Old 10-01-2013, 12:04 PM   #10
roSSco
∞ Smiles per mile
roSSco's Avatar
Drives: 2013 ZL1 Summit White A6
How many miles on your tires? Are they the stock Goodyears? I can stay near 70 even in heavy rain with mine. Only about 6000 miles on them.
2013 ZL1 #4739
'Heisenberg'
Color - Walter White
Roto-Fab CAI
On Reddit? Check out /r/ZL1/
roSSco is offline   Reply With Quote
Old 10-01-2013, 12:13 PM   #11
RexZL1
RexZL1's Avatar
Drives: 2013 ZL1
PTM1 is helpful if you have to pass, etc. If you have a manual and throw it down a gear and get on it to pass, you will go to ditch without PTM1. If you go hard you may end up in a ditch even with PTM1, cause the ZL1 is a badass!
RexZL1 is offline   Reply With Quote
Old 10-01-2013, 12:21 PM   #12
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
That's all in your head because your afraid your gonna lose control. From my experience, this car is well planted in the rain. I've driven it more times than I can count in tropical down pours doing 70-80 mph. I think it's also awesome you don't even have to use the wipers, due to the air flowing over the cowl and wind shield.
Old 10-01-2013, 12:23 PM   #13
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
I believe it is.
christianmotox is offline   Reply With Quote
Old 10-01-2013, 01:46 PM   #14
snackbar64
snackbar64's Avatar
Very interesting. I must try without wipers.
