06-09-2011, 08:39 PM | #1 | |
13 story building tipped over
Apparently they were putting in a garage next to the building and a storm dug out the foundation:
Anyone who bought an apartment here sure has a problem. Talk about a collapsed market! YES, IT'S An ENTIRE 13-STORY BUILDING IN CHINA LYING ON THE GROUND. (1) An underground garage was being dug on the south side of the building, to a depth of 4.6 meters (15 ft). (2) The excavated dirt was being piled up on the north side of the building, to a height of 10 meters (32 ft). (3) They dug right up to the base of the building. Then the rains came. (4) The building experienced uneven lateral pressure from north to south. (5) This resulted in a lateral pressure of 3,000 tonnes, which was greater than what the un-reinforced pilings could tolerate. Thus, the building completely toppled-over in a southerly direction. *First, the apartment building was constructed.* Then the plan called for an underground garage to be dug out. The excavated soil was piled up on the other side of the building. *Heavy rains resulted in water seeping into the ground.* The building began to tilt. Then it began to shift, and the "hollow" concrete pilings were snapped due to the uneven lateral pressures. And thus was born the eighth wonder of the world. If these buildings were closer together, it would have resulted in a domino effect. Notice that there's NO rebar in the pilings! Just some wire mesh. They built 13 stories on grade, with no basement, and tied it all down to hollow pilings with no rebar. Brought to you by the same folks that make your kids' toys and want to build your next car. Now that, folks, is a true snafu. Don't you feel better now that these are the folks that manufacture nearly EVERYTHING we buy and use today? One more product "MADE IN CHINA "...!!
06-09-2011, 08:59 PM | #2 |
Drives: 1990 rs 3.1 v6 Join Date: Jun 2011
13 story 13 very unlucky number should never build just 13... thats why elevators dont have a floor 13 lmaoo
06-09-2011, 09:03 PM | #3 |
Drives: 1SS Summit White Join Date: Jun 2010
i like how it managed to fall in one piece
06-09-2011, 09:05 PM | #4 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
DAMN CHINESE DRYWALL!!!
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
06-09-2011, 09:11 PM | #5 | |
06-09-2011, 09:13 PM | #6 |
the fact that its in one piece does say something about there work
06-09-2011, 09:15 PM | #7 |
just get a crane lift it back up and replace it lol
06-09-2011, 09:21 PM | #8 | |||
So much for building codes
06-09-2011, 09:26 PM | #9 | |
06-10-2011, 08:00 AM | #10 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
Overburden pressure + rain = bad news
06-12-2011, 06:57 PM | #11 |
06-12-2011, 06:59 PM | #12 |
those damn crafty chinese
Similar Threads | ||||
You won't believe this story folks. The HORROR! | MacTruck | 5th Gen Camaro SS LS LT General Discussions | 152 | 01-30-2010 06:49 PM |
My Camaro Story | GSmithPharmD08 | Member Car Journals | 38 | 01-23-2010 08:10 AM |
Camaro5 member feature story in the Providence Journal (R.I.) | PAUL SS | USA - New England | 1 | 10-26-2009 01:32 PM |
GM Building New GEN-5 V-8 in St. Catharines | camaro5 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 47 | 09-22-2009 12:34 AM |
Warning: long and boring story of how the camaro changed my life. | byebyeImports | 5th Gen Camaro SS LS LT General Discussions | 15 | 08-28-2007 12:18 AM |
