07-12-2016, 05:37 PM | #1 |
Drives: Black 14 camaro 1SS Join Date: May 2016
Any new fluids for manual trans and diff??
So I have a LS3 and I've read a few threads about which oils to use for the transmission and diff and see that the redline D4 for trans and redline 75w90 with the modifier already in it is the way to go for the diff.
However being that most threads i found were around 3 years old I wanted to ask if people were currently using anything new or if there were any other recommendations on what to use Thanks. |
07-12-2016, 08:04 PM | #2 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Cant go wrong with the redline stuff. Ive got all mobil1 fluids and no issues
07-13-2016, 07:55 AM | #3 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
Mobil 1 Synthetic ATF is very good in the LS3's manual transmission. Used it for about 40k miles with good results. I switched to a Redline blend but will switch back to Mobil 1 when I get the opportunity. It just worked better for me especially for synchronizer functionality on downshifts. You need to specifically look for the Mobil 1 ATF that says compatible with older DEXRON 3 applications. If you buy the fluid for late model transmissions, you are buying the wrong fluid. Confusing, I know.
-Mark. |
07-13-2016, 08:19 AM | #4 |
alright cool thanks guys
07-13-2016, 10:24 AM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
I've had the best luck with Royal Purple Synchromax in the the TR6060. Worst luck with Mobil 1.
RP made it noticeably smoother, M1 ATF noticeably more notchy. Haven't tried Redline as RP works so good. |
07-17-2016, 02:36 PM | #6 |
I'll probably offend you
I just finished putting in Redline D4 ATF and Redline diff fluid after hearing great things. If there are any issues I'll be sure to post about them.
07-17-2016, 05:32 PM | #7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I use Amsoil and haven't had any issues. It really helped with the transmission. I'm sure any quality fluid will be fine.
More to come. |
08-03-2016, 03:53 PM | #8 |
Drives: 2013SS IOM LS3 Join Date: Mar 2013
I have a little over 28k miles and still havnt changed my transmission or diff fluid in my M6. so the popular vote for fluids for these 2 go to...?
CamaroSS - Daily 476whp@6300rpm, 2001 Dodge Viper GTS - Toy (sold)
08-03-2016, 06:33 PM | #9 |
Founder of Cocoa Studios™
Just got back from the dealer changing my oil and rear diff fluid. Mobil 1 all the way around, had to bring my own oil filter. If your looking for a good rear diff fluid Mobil 1 SAE 75w-90 has you covered at a reasonable $13 from O'Reilly.
iOS developer of Snap Organizer and founder of Cocoa Studios.
08-05-2016, 11:27 AM | #10 |
hmmm gotcha, still not sure on what to use for the M6 considering there are various options...
08-11-2016, 02:47 PM | #11 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
Amsoil front to back for me.
09-01-2016, 10:23 PM | #12 |
Drives: 2013 camaro 1le Join Date: Sep 2012
I changed my transmission oil to amsoil synthetic signature series ...... Tr 6060 is still noisy (with only 3800 miles)I feel very little difference if any !
09-01-2016, 11:40 PM | #13 |
signature series is motor oil not transmission oil. get that out of there now. you need to put ATF in the transmission.
09-02-2016, 04:18 PM | #14 |
Thread Tools | |
