01-03-2011, 10:58 PM | #1 |
Putting HIDs in tomorrow
Will be installing my bfxenon HIDs tomorrow anything I should be aware of or is it a fairly simple install?? Thanks for your input
01-04-2011, 08:55 AM | #2 |
Drives: '69 SS Convertible Join Date: May 2009
Are you just doing the HID kit in your Halogen housing? If so, it's pretty straight forward. Look through this DIY.
http://www.camaro5.com/forums/showthread.php?t=69917 Which color of lights did you buy? Now...when your ready you should consider doing a HID projector retrofit. The performance and visibility is 100x better. You'll probably get people flashing thier brights at you on occassion with just the bulb in a Halogen housing. You won't get that with a retrofit. http://www.camaro5.com/forums/showth...70#post2687670 Let me know if you have any questions.
Build Journal |
01-04-2011, 09:38 AM | #3 |
Yeajust simple swithchout..thanks!
01-04-2011, 09:45 AM | #4 |
i bought the 6000k lights is that what you have in yours?
01-04-2011, 10:06 AM | #5 |
Well....I now have HID projectors with 5000k lights.
When I was using the HID bulbs in my halogen housing I originally tried 8000k because they were the most popular. They were too blue for my taste and they actually cut down a little on visibility. After about 2 wks I went to 6000k which were much better. That's the color I would recommend personally. BTW: I'm about to pull off my V-LED 6000k fog lights because I'm going to go to a 5000k set. If you're intrested in some let me know and I'll sell them to you pretty cheap. I hate to see them just sit on my workbench.
Build Journal |
01-04-2011, 10:45 AM | #6 |
i wish i knew about your fogs..i purchased them and will be installing them as well...any write up on those?
01-04-2011, 10:59 AM | #7 |
This might help.
http://www.camaro5.com/forums/showthread.php?p=2122839 http://www.camaro5.com/forums/showth...ght=fog+lights ..... post #5 Definatley recommend taking the fog light housing out....100x easier to plug in the bulbs that way. They seem a little difficult to do the first time but once you've done them they are pretty easy. I can have my fog light housing out in about 5 mins. Unfortunatley I've had to do it a couple times. If you have the means, it's easier to get to them by releasing two of the clips on the inner fender well. Those are super easy to take off and even easer to put back on. That will give you a little more room to get to the black ring that holds the housing in. It's not a must but just makes it easier. Which fog lights did you buy?
Build Journal |
01-04-2011, 11:47 AM | #8 |
you wouldnt happen to have your old bulbs would you??
01-04-2011, 12:42 PM | #9 |
Which bulbs? The halogen or the 8k bulbs?
Build Journal |
01-04-2011, 01:23 PM | #10 |
Hey guys what are the stock rs lights 4000k? Do They sell the same style for the fogs I assume? Is there anything other than switch them out or does it involve alot of work?
01-04-2011, 01:45 PM | #11 | |
The RS bulb is different than the non-RS.
Build Journal Last edited by caverman; 01-04-2011 at 02:09 PM. |
01-04-2011, 04:56 PM | #12 |
Here's the problem the part that twists into the headlight housing broke in half. Was wondering if you were using your bulbs at all and could spare the part
01-04-2011, 04:57 PM | #13 |
I bought the 6k bfxenon to match the headlights. I think there is a need to snip wires in this install?
01-04-2011, 05:43 PM | #14 | ||
The other reason I didn't do BfXenon's fogs is for price. You can get the V-LEDs shipped for right around $100. I'll probably be selling mine for about 1/2 that. They look great for 6k. Just a little too blue for me now. I just pulled my 6k fogs off and put in my old AAC ones. They are almost too white for the 5k lights I have but not too bad. I think I'm going to leave them this way for a while since they didn't cost me anything.
Build Journal |
Similar Threads | ||||
Papa John's Giving Away Free Pizza To Any Camaro Owner Tomorrow! | Blue Maro Demon | 5th Gen Camaro SS LS LT General Discussions | 331 | 02-13-2012 10:29 PM |
Tomorrow Meet | Sam Friedman | USA - California | 5 | 11-22-2009 04:38 AM |
Picking ZEUSS up tomorrow!!!! (w/pics) | khislop007 | Camaro Photos | Spyshots | Video | Media Gallery | 10 | 09-28-2009 08:38 PM |
What do I need to know for ordering tomorrow | kdbolt70 | Camaro Price | Ordering | Tracking | Dealers Discussions | 6 | 01-22-2009 10:20 PM |
