07-28-2014, 06:16 PM | #1 |
Drives: 2013 1ss 1le Join Date: Mar 2014
confused by mph and et time
trying to figure out why my mph is higher than those running faster e/ts. I have a 2013 camaro ss 1le with cai ptb solo cats and outlaw exhaust with no tune on stock tires. I have been consistently running 13.3 qtrs at 110 to 111 mph. my 60 ft is 2.2 to 2.3. my question is I ran another ss at the track on Friday he beat me by 2 100's of a second but ran 106 mph and I ran 111 mph he had a 2.1 60ft and I had a 2.3 60ft. just seems like a big difference in mph for 2 100s of a second for the full quarter. was it all in the 60ft?
07-28-2014, 06:54 PM | #2 |
Drives: none Join Date: Aug 2011
Probably. And if you're both M6, it's all driver.
07-28-2014, 07:09 PM | #3 |
he was auto and squeezing. my confusion is in mph difference
07-28-2014, 07:10 PM | #4 |
11 Sec. Bolton car.
Drives: 09 G8 GT Join Date: Nov 2013
You are making more HP but he was the better driver.
09 Pontiac G8 GT 11-second bolt-on car
07-28-2014, 07:11 PM | #5 |
Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
Driver and car.
The 1LE had wider tires so they can be a tad slower at a drag strip plus those stock F1's are not good for hooking. Seen several stock and modded ZL1's have 120 trap speeds but 13-14 second ET's. On a track you would have the advantage, drag strip is a little different. When you feel like it, get some LTH, DR's and tune that beast and your ET's and trap will greatly improve. |
07-28-2014, 07:13 PM | #6 |
Squeezing what?
When you're talking stock-ish cars on radials the M6 should out MPH the auto and the auto will probably out ET all but the best M6 drivers. Squeezing.....??? Spraying? WTF was he spraying if that's all the car ran? lol |
07-28-2014, 08:09 PM | #7 |
Drives: C6 Corvette Join Date: Sep 2013
Wouldn't worry about the MPH too much in your case. Focus on you 60' You take .3 or .4 off (which is possible with what you have) and you could run a high 12 at the same MPH if not slower
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
07-28-2014, 09:03 PM | #8 |
He had a bottle in there said he sprayed his nitrous. I thought with that he would have killed me. Also the track is at 2400ft above sea level if that makes a difference.
07-28-2014, 09:19 PM | #9 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
old saying every .1 sec off the 60ft = .2 sec off the e.t.
07-28-2014, 10:01 PM | #10 |
Thread Ender
Drives: 2010 Camaro 2SS/RS L99 Join Date: May 2011
07-28-2014, 10:06 PM | #11 |
07-28-2014, 10:23 PM | #12 |
It is a good rule of thumb for most street cars. its because the first 60' takes the longest amount of time to do (feet per second) compared to anywhere else down the track
the faster the car and the faster the 60' the more it begins to get closer to a .1 to .1 ratio |
07-29-2014, 12:13 AM | #13 |
Drives: 2011camaro SS Join Date: Nov 2012
Simple answer: your 60ft blows! As in you are either blowing your tires away, or you come out like grandpas pecker, soft and with no vinegar!
Either way, you have got to get your 60ft down. You should easily be around a 2.0 and that will make a huge difference on your ET. mph means nothing if your losing the ET race! |
07-29-2014, 12:40 PM | #14 |
Thread Tools | |
