Old 06-27-2013, 07:12 PM   #1
Unknown SSRS
Drives: 2011 VR SS/RS
HELP! with Tire size!
buying tires soon! need help! I have 20x10 wheels... all 4 corners... offset +29 all corners.. will I be able to run 295/35/20 all around? or will it rub? I am currently running 275/40/20 all around. I am dropped on H&R sport springs... 1.4in drop in the front and 1.3 inch in the back drop.
looking to get Michellin Pilot super sport.. 295/35/20 all 4 corners
Unknown SSRS is offline   Reply With Quote
Old 06-28-2013, 08:00 AM   #2
Unknown SSRS
anyone? someone?!
Old 06-28-2013, 11:39 AM   #3
camarostar2010
Drives: 2011 SS
I have 315 in the back but the rim is wider. Up front I think u can do 295 but u might need a spacer or a camber adjustment kit. For now I recommend you deal with the rear aspects. And the front you can tackle later. Truth be told the stock rims should be avoided. They just arent wide enough. Sorry I can't help with more specifics
camarostar2010 is offline   Reply With Quote
Old 06-28-2013, 12:27 PM   #4
Unknown SSRS
I don't have stock wheels 8).. have the Rohana RC10's in 20x10 +29 offset all around. I know the 295/35/20 will fit in the back.. just not 100% sure about the fronts.
Old 06-28-2013, 04:53 PM   #5
camarostar2010
Drives: 2011 SS
well...time to try it out. I know that pedders has done a 305 set up up but with camber adj and a coil over shock set up. He is a good guy to get these answer from...google it !
Old 06-28-2013, 05:03 PM   #6
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
You're losing a slight amount in circumference and overall tire height compared to the 275/40 so that should work.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
